ArcGIS Online
Earthquake impact analysis using ArcGIS Online and ArcGIS Living Atlas
Note
Analysis is currently only supported in Map Viewer Classic. It will be available in a future release of Map Viewer.
In this simple exercise you will determine the total population that is within proximity of an earthquake with measured shake intensity. The analysis will be performed using ArcGIS Online tools with ArcGIS Living Atlas content. Note that appropriate privileges are required to use analysis tools to complete the exercise. The workflow is:
Make a map of recent earthquakes
Step 1 — Go to the Living Atlas website and sign in using your ArcGIS organizational account.
Sign in
Step 2 — Open the Browse tab and enter “recent earthquakes” in search.
Search
Step 3 — Locate the Recent Earthquakes feature layer and click the thumbnail or title to open the item details.
From the Recent Earthquakes item details we learn that quakes are displayed by magnitude along with impact information. Events are updated as frequently as every 5 minutes and are available up to 30 days, except for events of magnitude less than 3.0 (retained 3 days) and events of magnitude less than 4.5 (retained 7 days). Labeled quakes are those with a PAGER alert, a measure of the scope and impact of the event.
Step 4 — Open the layer in a new map. Save the map for future use.
Open in Map Viewer
Locate a quake event for analysis
Step 5 — Explore the map to find an area of interest. As you explore the map, click features to learn more about them.
The Events by Magnitude layer pop-up displays the magnitude, depth, date, time, PAGER alert status, and includes a link to the USGS event details.
Pop-up information
The Shake Intensity layer pop-up displays the Mercalli Scale intensity and a description of what was felt and any expected damage.
Pop-up information
At the time of writing this article, a quake near Perry, Oklahoma, was chosen for the analysis.
Earthquake event
Filter shake intensity
Apply a filter to the Shake Intensity layer to show areas with an intensity of 4 or greater, eliminating the lesser intensities where the quake is less likely to have been felt or cause damage.
Earthquake intensity
Step 6 — Open the Shake Intensity layer filter.
Quake Intensity filter
Step 7 — Create a filter expression.
Expressions use the general form of <Field_name> <Operator> <Value, Field or Unique>. Use the dropdown menus to create the desired filter, in this case Intensity value is at least 4. When finished, apply the filter.
Filter expression
Dissolve the boundaries
Step 8 — Since there may be overlapping or disconnected polygons matching the expression, dissolve the layer to create a single, multi-part polygon for additional analysis.
a — Click Analysis.
b — Open the Manage Data group.
c — Select Dissolve Boundaries.
Dissolve analysis tool
Step 9 — Enter the Dissolve Boundaries tool parameters.
a — Select the Shake Intensity layer.
b — Accept the defaults to create multi-part features.
c — Enter the layer name for the result.
d — Ensure that you have zoomed to the extent of the earthquake of interest and check Use current map extent. Since we are not interested in other earthquakes, this limits the analysis to this particular event and minimizes credit consumption for the analysis.
e — Click Run Analysis to perform the analysis.
The result of Dissolve Boundaries is a single layer with a single multi-part polygon. Click the polygon to view the aggregated area.
Dissolve analysis result
This new layer can be used for further analysis. In the next steps, the layer will be enriched to determine the number of people that experienced an intensity level of 4 or greater.
Step 10 — Enrich the layer.
a — Click Analysis.
b — Open the Data Enrichment group.
c — Select Enrich Layer.
Enrich Layer tool
Step 11 — Enter the Enrich Layer parameters.
a — Select the dissolved Shake Intensity layer from Step 8.
b — Click Select Variables.
Enrich Layer
This opens the Enrich Layer Data Browser.
c — Select the Population data category.
Next, choose the variables that you want to apply.
d — Check 2020 Total Population.
e — Click Apply.
Choose variables
Complete other Enrich Layer parameters by entering the following:
f — Output layer name.
g — Use the current map extent, since we only want to apply the analysis to the current polygon.
h — Click Run Analysis to apply the selections.
Enrich Layer analysis
The enriched polygon now includes 2020 population counts. The image below shows a configured pop-up for the result showing the size in square miles and the 2020 total population within the polygon.
Enriched polygon
More information
For more information, see the following:
This article was originally published on February 15, 2018, and has been updated.
About the author
Corporate technology evangelist and advocate at Esri, focusing on ways to broaden access to geographic information and helping customers succeed with the ArcGIS system. On a good day I'm making a map, on a great day I'm on one. Email bszukalski@esri.com or connect on LinkedIn (https://www.linkedin.com/in/bernszukalski/).
Connect:
Next Article
Baby Steps to Quantum Leap
Read this article
