ArcGIS Enterprise
Insights tip: Share your analysis using Story Maps
Insights for ArcGIS is a great product to use when you need to do analysis, but sometimes just doing the analysis isn’t enough.  Communicating your results with clients and colleagues is often required, and one of the best ways to share your results is through Story Maps. This blog will walk you through the steps to share your results and embed them into a Story Map Journal, one of the most popular Story Map templates.
Check out the Story Map Journal that I made to share my analysis.
Before you begin
This blog deals with the steps you perform after you have completed your analysis.  You can follow along with the steps using a page from your own analysis, or by first completing the exercise Get started with Insights for ArcGIS up until the steps when you share your results.
You will also need to create a new Story Map or open an existing Story Map.  The Story Map does not need to be made with the same account that you use for Insights, and can even be created in ArcGIS Online.  For more information on creating Story Maps, see the Story Map Journal Tutorial, or a tutorial for another Story Map template.
Share your page in Insights
In order to view your analysis from Insights in a Story Map, you will need to share your Insights page.  Shared pages can be viewed by members of your organization or the public, even if the viewer does not have an Insights license.  The data on a shared page cannot be updated or analyzed, but the viewer can interact with cards, including making selections, zooming and panning on a map, and flipping the cards to view statistics.
Before you share your page you should consider some of the following edits:
Once your cards have been organized the way you want them, go to your Page options menu and click Share Page.
Share a page in Insights
The Share Page window opens and you can enter a Title, Description, Tags, and Share with options.  You must share your page with Everyone if you plan to make it public or create the Story Map in ArcGIS Online.  If your Story Map is staying within your organization then you can share the page with just your organization. Click Share to share your page.
When your page is shared, the window will display three new options: View your shared page, Access your page item, and Embed. You are going to use the <iframe> from Embed to display your page in a Story Map.
Add an <iframe> to your story map
An <iframe> is used to embed your shared Insights page in your Story Map as a web page. When you add new content to a Story Map Journal, Story Map Cascade, or a Story Map Series, you will have the option to add a web page.  Copy the <iframe> from your shared page and paste it under Embed code.  Click Configure to change the position or size of the embedded page, then click Save.  Your Insights page will now be embedded into your Story Map.
Embed an iframe in a Story Map
If you haven’t already, check out the Story Map that I made to share my analysis in Insights:
Story Map Journal
Resources
Share your work in Insights
Share items in Portal for ArcGIS
Embedding apps and websites in Story Maps
Story Map Cascade Tutorial
Story Map Series Tutorial
Do you have and any tips you’d like to share or questions you need answered? Leave your questions and blog requests in the comments section.
About
Vicki Lynn Cove studied biology, English literature, and GIS before beginning work at Esri as a Product Engineer on the Analysis and Geoprocessing team. In her spare time, Vicki Lynn enjoys fibre arts, playing her guitar, and the outdoors.
Next Article
Check out Esri's new Landsat Explorer web app
Read this article
