Field Operations
Vector Basemaps Available in GCS WGS84 (Beta)
For several years now, most world basemaps delivered on the web (including those from Esri) have been delivered in the Web Mercator coordinate system.  To be precise, the Esri basemaps are delivered in the WGS84 Web Mercator (Auxiliary Sphere) coordinate system.  This coordinate system is used by most consumer-facing mapping platforms and has become the de facto standard for web maps.
In prior years, Esri had delivered its world basemaps in Geographic Coordinate System (GCS) WGS84.  We still host a couple ‘legacy’ map services (now in ‘mature support’ and not actively maintained) in GCS WGS84 to support users that had an affinity for that coordinate system or could not update their maps and apps.  There are some organizations, such as in the Defense/Intelligence community, that have a requirement to use maps in GCS WGS84.  To support these organizations and other use cases, Esri is introducing a new set of vector basemaps (now in beta) that are delivered in GCS WGS84.
Last year, Esri announced the availability of a new World Imagery (WGS84) tile layer in this coordinate system.  This version of the World Imagery map features the same set of imagery that is published in our standard World Imagery map, but is delivered in a new tiling scheme (i.e. “WGS84 Geographic, Version 2”) based on the GCS WGS84 coordinate system.  The new vector basemaps in GCS WGS84 are designed to complement the World Imagery (WGS84) map, so they can be used separately or together.  You can see an example of this in the Imagery Hybrid map below, which combines the World Imagery (WGS84) tile layer and a hybrid reference layer built with the new vector tiles.
[iframe width=”100%” height=”400″ frameborder=”0″ scrolling=”no” marginheight=”0″ marginwidth=”0″ title=”Custom Canvas Map” src=”https://www.arcgis.com/apps/Embed/index.html?webmap=4c2b44abaa4841d08c938f4bbb548561&extent=-171.8262,-61.875,163.5645,90&zoom=true&scale=false&disable_scroll=true&theme=light&search=true”]
Map Styles
One of the advantage of vector basemaps is that they can support a wide range of map styles based on a single set of vector tiles.  Esri intends to make available the same set of ‘core’ map styles (currently including 9 maps) for both our maps in Web Mercator and GCS WGS84.  Esri will publish both web maps and vector tile layers for these vector basemaps.  You can find these maps and layers in the Vector Basemaps (WGS84) group, and filter the group for what you need.  If you would like to include these maps in your organization’s custom basemap gallery, we would recommend using the maps for that purpose.
Compare Styles of Vector Basemaps in GCS WGS84 (click image to view app)
“Small Print” Notes
About the author
Deane Kensok has been with Esri since 1990 and is currently the ArcGIS Content CTO and a member of the Living Atlas team. For the past twenty years, Deane has worked on a variety of Internet mapping and data publishing products and projects, which have led to his current work with ArcGIS Online and the Living Atlas.
Connect:
0 Comments
Inline Feedbacks
View all comments
Next Article
Empowering Communities with Open Data
Read this article
