ArcGIS Blog
Announcements
ArcGIS Pro
In ArcGIS Pro 3.5, Calculate Field does not honor selection or layer filters when using SQL as the expression type on file geodatabase data
By Kory Kramer
Update June 12, 2025
The ArcGIS Server 11.5 Calculate Field patch is available: https://support.esri.com/en-us/patches-updates/2025/arcgis-server-11-5-calculate-field-patch
Update June 5, 2025
This issue is fixed in ArcGIS Pro 3.5 Patch 1 (3.5.1). Each patch is cumulative of all previous patch fixes. It is highly recommended to apply the most current patch immediately after installing ArcGIS Pro 3.5.
The ability to set the expression type to SQL in the Calculate Field geoprocessing tool when working with file geodatabase (.gdb) data was introduced in ArcGIS Pro 3.5. A potential data corruption bug has been discovered wherein Calculate Field does not honor the active selection or layer filters (for example, definition query, time filter, range filter, or spatial filter) when using a SQL expression on file geodatabase data, resulting in all rows being calculated.
Cause
BUG-000176644: Calculate Field does not honor active selection or layer filters when using a SQL expression on file geodatabase data, resulting in all rows being calculated.
Workaround
When using Calculate Field, to preserve the original values of your data, make a copy of the input table as a backup, or use the Enable Undo option in the Geoprocessing pane.
  • Do not use SQL as the expression type until this bug is addressed with a patch. Use Python or Arcade as the expression type.
  • Do not publish web tools from ArcGIS Pro 3.5 to ArcGIS Enterprise 11.5 that include Calculate Field using SQL as the expression type.
Conclusion
This issue will be addressed in 3.5 Patch 1 (3.5.1), planned to be available the first week of June 2025. Until a patch is available, the software update service will be disabled in ArcGIS Pro. A corresponding ArcGIS Enterprise patch will also be made available.
Customers who understand this issue and the workaround can download ArcGIS Pro 3.5 from My Esri.
Share this article
3 responses to “In ArcGIS Pro 3.5, Calculate Field does not honor selection or layer filters when using SQL as the expression type on file geodatabase data”
    • Hi Joshua. Yes, to be clear, the ability to use a SQL expression type in the Calculate Field geoprocessing tool against file geodatabase was introduced in ArcGIS Pro 3.5. That is the affected scenario. SQL Server or PostgreSQL data would be unaffected.
  1. Not sure if this is a known issue but something to note, we’re seeing this same behavior with Arcade Calculate Field Expressions and Def Queries in 3.3.5 also.
Leave a Reply
