Electric & Gas Utilities
Water Utility Mobile Map and Leak Survey Mobile Map Product Retirement Announcement
July 1st, 2017 the Water Utility Mobile Map and the Leak Survey Mobile Map Solution Products will move to the Retired Lifecycle Phase.
The Water Utility Mobile Map and the Leak Survey Mobile Map are ArcGIS for Windows Mobile based applications. As such their lifecycles follow the Product Lifecycle of ArcGIS for Windows Mobile.
It is recommended that organizations using ArcGIS for Windows Mobile use Collector for ArcGIS, Survey123 for ArcGIS, Workforce for ArcGIS or Explorer for ArcGIS to support their workflow needs.  Organizations can also explore building custom mobile solutions and can refer to Building Apps to understand potential development paths forward.
Water Utility Mobile Map users should consider deploying a set of focused apps with Collector for ArcGIS and foundational network maps for mobile viewing and redlining of water, sewer and stormwater networks within any ArcGIS app.
Leak Survey Mobile Map users should consider deploying the Leak Survey Collector.
The Water Utility Mobile Map and Leak Survey Mobile Map are open source. When retired their shared source code will remain available on GitHub at https://github.com/Esri/water-utility-mobile-map.
About the author
Howard leads the Esri team developing ArcGIS Solutions for electric, gas, water, sewer, stormwater, communications, renewables, and district heating and cooling.
Connect:
0 Comments
Inline Feedbacks
View all comments
Next Article
ArcGIS Production Mapping and ArcGIS Defense Mapping: Getting Started with Generalization
Read this article
