Initial: 10/28/26 – Updated: 11/17/26
On October 22, 2026, Open AI security researchers announced a critical severity vulnerability in Google’s Brotli decoder, identified as CVE-2026-111497. This CVE was listed as a Known Exploitable Vulnerability (KEV) on 10/27/26 and has multiple names including Node2Shell, Broccoli2Shell, and HTTP2Shell. Patches for applicable products are being released incrementally and additional release status updated here.
ArcGIS Product Status
- ArcGIS Online
- Mitigating measures deployed and updates in progress
- ArcGIS Enterprise – Affected – Critical Severity – CVSS 9.4
- 11.5, 12.0, 12.1, NEW 12.2 Patch Available (Security 2026 Update 4)
- This cumulative security patch specifically addresses ArcGIS Server Brotli Node.js (11.1 and 11.3 are not vulnerable this Brotli Node.js issue)
- If you had applied the temporary mitigation of disabling ArcGIS Enterprise SDK custom data feeds, you can safely reenable such capability after applying this patch.
- ArcGIS Mission Server – Affected
- ArcGIS Pro
- 3.5 and later – Affected – Patch Pending
- Customers utilizing mature or retired product versions should upgrade their deployment.
NEW – Products with Component Pre-Requisites
Node.js
- The following products utilize Node.js which customers deploy and update separately from our products. Please update your customer-managed Node.js versions immediately as specified below:
- ArcGIS Enterprise SDK – 11.1, 11.3, 11.5, 12.0, 12.1
- Application Server – Solutions built and deployed with the SDK to ArcGIS Enterprise with ArcGIS Server Patch 4 are not vulnerable.
- Developer systems – Installing SDK versions before 12.2, you will: 1) Install an older Node.js version (compatible with your SDK version), 2) Complete the SDK install and 3) Upgrade/patch Node.js to a non-vulnerable version.
- Experience Builder
- Application Server – If you use Node.js, ensure you patch it.
- Developer systems – Ensure you patch Node.js version.
Microsoft .NET Runtime
- The following products utilize the .NET runtime which customers deploy and update separately from our products. Please immediately update your .NET Runtime to a patched version from Microsoft here.
- ArcGIS Pro
- ArcGIS Enterprise ArcGIS Web Adaptor (IIS)
- ArcGIS Enterprise SDK SOEs/SOIs
- ArcGIS Cloud Builder
- Apps build with ArcGIS Maps SDK for .NET 200.0 or later for Windows or Android are potentially affected. No update for the ArcGIS Maps SDK needed, instead update your .NET Runtime and rebuild the apps.
We strongly recommend having processes in place to update customer managed components such as Node.js and .NET runtime component regularly (See ArcGIS Enterprise Hardening Guide).
Additional information concerning this vulnerability and ArcGIS products will be posted here when applicable.
