Software Engineering Blog
Testing & QA
Testing: Your Path to Quality Software
By: Nidhi Kumar
Quality is a crucial aspect of software development, but achieving it requires more than just good intentions. This blog explores how integrating thoughtful and effective testing practices into your team’s workflow can gradually enhance your software. To truly make these practices work, a well-defined roadmap is the key.
Test Plan: Your Testing Roadmap
In the Developer Technology Group at Esri, we develop detailed test plans to thoroughly test our software’s critical areas. These plans focus on several key areas, including:
  • Test Objectives: These are essential in providing clear direction for each phase of the testing process. They serve as a guiding framework, ensuring that all stakeholders understand the specific goals —whether it’s confirming functionality, evaluating performance, or assessing usability.
  • Test Strategy: A test strategy is a high-level plan that outlines the quality assurance approach for achieving test objectives, including scope of testing, roles and responsibilities, environment, tools, risk assessment, and metrics for tracking success. For example, in GIS applications, performance and spatial accuracy are critical. Test strategies focus on making sure maps load quickly and data analysis is precise, which is essential for making informed decisions.
  • Test Environment: An effective test environment is your weapon for catching bugs before they reach your users. It’s about creating a space that replicates real-world conditions as closely as possible. Imagine your GIS application needs to run seamlessly across multiple platforms. To catch those tricky, platform-specific issues, your test environment should mimic each one down to the last detail.
  • Test Schedule: To create a test schedule, begin by understanding the scope and objectives, breaking down testing into phases like unit, integration, and system testing. Estimate the time and resources needed for each phase, align them with development and release plans, incorporate buffer time, and communicate the schedule to all stakeholders. Regularly monitor progress and adjust as needed to stay on track and meet overall goals.
Test Design and Test Cases
After the test plan is completed, test design process begins. This involves turning the strategies outlined in the test plan into actionable steps. A key part of this is creating test cases, which are specific scenarios that verify whether the software functions as expected. In this section, we’ll focus only on test cases, as they play a vital role in ensuring software quality. Here are the key traits of well-written test cases:
  • Clarity and Completeness: Ensure each test case leaves no room for interpretation. For example, when testing API endpoints, include precise details such as the HTTP method, required headers, payload, and exact expected JSON response structure. This level of detail prevents any confusion during execution or automation.
  • Reusability: Design modular test cases that can be leveraged in different contexts. For example, create a generic data validation test for input fields that can be reused across various forms, such as sign-up, payment, and user profile forms. This allows for consistent testing and easier maintenance when field validation rules change.
  • Prioritization: Apply risk-based testing to identify and prioritize the most critical test cases. For instance, in a banking application, prioritize testing around financial transactions, such as wire transfers or loan calculations. This ensures that the most impactful and potentially damaging issues are addressed first.
  • Measurability: Ensure that the expected outcome of a test case is measurable and clearly defined. This allows testers to easily determine whether the test has passed or failed.
  • Traceability: Connect each test case to the requirement it tests and any issues it discovers. For example, in a GIS app, if you’re testing a feature that allows users to find all parcels within a certain distance from a point, make sure the test case is connected to that specific requirement. If any issues arise, like incorrect results or slow performance, they should be easily traceable back to the original requirement. This ensures that everything is properly tested and that any problems can be quickly identified and fixed.
  • Automation: Focus on automating tasks that are repetitive or time-consuming. For example, to ensure that all download links for software tools function correctly after every website update. By setting up automated tests to check these links, you enable continuous testing and get instant feedback on any issues, speeding up the development process and making the website more reliable.
Holistic Testing: Raise the bar
Holistic testing is a comprehensive approach to software quality assurance that evaluates the entire system—functionality, performance, security, and user experience—rather than focusing on isolated components. The process begins by defining the purpose and aligning testing objectives with real-world user needs.
Planning should start weeks before a release, ensuring that preparations like selecting the testing environment and creating test scenarios are in place, giving development teams time to incorporate feedback. If pre-release testing isn’t feasible, holistic testing can be conducted immediately after launch or on existing features, though this is less ideal. Testing typically starts with small-scale internal trials and expands to larger, more complex tests, often using dedicated test machines or cloud platforms. A kickoff meeting with the entire group sets expectations, and the process ends with a feedback round to prioritize any critical issues.
This approach can uncover a wide range of issues, from costly production problems to user experience concerns. For instance, while an authentication module might securely handle passwords in isolation, holistic testing could reveal that they are logged in plaintext when integrated with the user profile system. Additionally, UI issues can be identified, such as users struggling to find the “Save” button after filling out a form because it was placed in a non-intuitive position.
Call for Action
Boost your testing strategies with these methods. Read my next blog to discover the benefits and detailed process of holistic testing.
Next Article
From Zero to Sixty in a Summer with Flutter
Read this article
