arcuser
GNSS Accuracy Unlocked: How Correction Methods Improve Field Data Collection
When a utility technician needs to locate an underground valve buried beneath snow and vegetation, or when a construction inspector must verify that a newly installed water line matches design specifications within a few centimeters, basic GPS accuracy isn’t enough. Today’s GIS professionals need positioning precision that ranges from submeter- to centimeter-level accuracy. Understanding the correction methods that deliver this precision—and knowing which method fits your project requirements—can mean the difference between efficient operations and costly mistakes.
What Is GNSS?
GPS has become the common technology for determining outdoor location using smartphones or specialized receivers. However, GPS is just one component of a broader positioning infrastructure, the Global Navigation Satellite System (GNSS). Many countries and regions now operate their own satellite navigation systems, including GLONASS (Russia), Galileo (European Union), BeiDou (China), QZSS (Japan), and NavIC (India).
The original GPS constellation, established in 1973 by the US Department of Defense, maintains about 31 active GNSS satellites out of the more than 100 operational satellites that orbit the Earth. In California, a multiconstellation GNSS receiver typically tracks more than 25 satellites simultaneously—a dramatic increase from the early days when users had to carefully plan collection windows to ensure adequate satellite visibility.
Why More Satellites Matter for GIS
Overhead satellite image of a busy intersection with multiple glowing blue location pins indicating specific vehicles.
The Global Navigation Satellite System (GNSS) provides a variety of services. These include helping transportation departments monitor traffic.
To calculate a three-dimensional position, a GNSS receiver must track signals from at least four satellites. More satellites provide several advantages for GIS data collection, including the following:
What High-Accuracy GNSS Can Do for GIS
Stand-alone GNSS typically provides two- to five-meter accuracy in open areas, but performance degrades in challenging environments with tree canopy, buildings, or other obstructions. For many GIS applications, this level of accuracy proves insufficient.
Consider these field scenarios where higher precision (submeter- to centimeter-level) matters:
What’s the Differential?
Differential correction techniques improve GNSS accuracy by calculating and removing systematic errors. The underlying principle has been the same for decades. Two receivers located relatively close together experience similar atmospheric and satellite errors. By calculating these errors at a precisely known location and applying corrections to a roving receiver, differential methods achieve higher accuracy.
However, today’s correction methods differ from methods of the past when it comes to implementation, coverage area, accuracy level, and cost structure. Understanding these differences helps you select the appropriate method for your projects.
RTK Positioning
Real-time kinematic (RTK) positioning remains the most popular correction method for achieving centimeter-level accuracy. It requires at least two GNSS receivers: a base station at a precisely known location and a rover collecting field data. The base station calculates errors by comparing its computed position against its known location, then transmits corrections to the rover.
Diagram depicting a cartoon man with a GNSS receiver, with multiple satellites pointing at him from various angles, each connected by a dotted line.
Modern GNSS receivers can track signals from multiple satellite constellations simultaneously, providing improved accuracy and reliability in challenging environments such as urban areas and dense forests.
RTK accuracy depends heavily on the baseline, which is the distance between base and rover. Manufacturers express baseline accuracy in parts per million (ppm). One ppm equals one millimeter of error per kilometer of distance. For example, a receiver with 8 mm + 1 ppm horizontal accuracy starts with 8 mm base accuracy, but at 30 km from the base station, accuracy decreases to 3.8 cm. As accuracy degrades with distance, initialization time also increases.
Network RTK (NRTK) and real-time network (RTN) technology use multiple base stations to cover wider regions, overcoming single-base RTK distance limitations. Virtual reference station (VRS) systems create a virtual base station near the user’s location by computing corrections from multiple reference stations.
Most GIS users rely on existing base station infrastructure rather than deploying their own stations. Options include permanent company-owned stations and third-party services from government agencies or commercial providers. In the United States, some state departments of transportation provide free statewide RTK services.
Understanding RTK Data Standards
Standardization plays a critical role in RTK operations. The Radio Technical Commission for Maritime Services (RTCM) Special Committee (SC) 104 standardizes RTK correction data protocols. In 2023, RTCM SC 134 standardized narrow-band ultra-high frequency radio data links, improving on earlier proprietary manufacturer protocols.
For internet-based corrections, Networked Transport of RTCM via Internet Protocol (NTRIP) serves as the widely adopted standard. Finding an RTK correction source means identifying an NTRIP caster—a server that broadcasts correction data. Each caster offers multiple mount points, which are unique identifiers for specific correction data streams.
Mount point selection matters because it determines which satellite constellations your rover can use. For example, Esri’s base station (a Trimble NetR9 receiver) in Redlands, California, provides three mount points: gisar23 (GPS only), gisar30 (GPS plus GLONASS), and gisaMSM5 (multiconstellation GNSS). Selecting gisar23 limits the RTK solution to GPS satellites, even if the rover supports additional constellations.
Satellite-Based Augmentation System
Photo of a man from behind his head depicting him adjusting a GNSS receiver against an out-of-focus background.
GNSS receivers help surveyors reduce position computing errors.
A satellite-based augmentation system (SBAS) provides free submeter-level accuracy in many global regions and commonly comes built into professional GNSS receivers. Government agencies operate SBASs, which collect corrections from multiple reference stations, relay data to a main station, and uplink corrections to geostationary satellites. Your GNSS rover receives corrections directly from these satellites. SBAS coverage regions include the following:
Each system covers a wide area—sometimes an entire continent. And because SBAS delivers corrections via satellite, it works in areas lacking cellular or internet connectivity.
Precise Point Positioning
While differential methods compute differences between base and rover measurements, precise point positioning (PPP) takes a different approach. It models error-causing factors and estimates corrections from a global network of reference stations. PPP offers several advantages: global coverage, no baseline distance limitations, and better accuracy than SBAS. It typically achieves 3- to 10-cm accuracy after an initialization period of about 20 minutes.
PPP-RTK represents the latest evolution in correction methods, combining PPP and RTK techniques to reduce initialization time while maintaining near-RTK accuracy. It uses reference station networks to compute satellite and regional atmospheric errors, then broadcasts correction data. Unlike standard PPP, PPP-RTK provides regional rather than global coverage.
The Earth, labeled GNSS and encircled by blue and purple orbital pathways, surrounded by various satellites, each labeled according to the country or region that operates it.
Several countries and regions operate their own satellite navigation systems
Both PPP and PPP-RTK can broadcast via internet or satellite. Satellite signal delivery makes these methods valuable for accurate positioning in areas without internet access. Beyond commercial PPP services, some governments provide free services including Japan’s Centimeter Level Augmentation Service from Quasi-Zenith Satellite System (QZSS) satellites and Galileo’s High-Accuracy Service (HAS). These services cover specific regions with varying accuracy and initialization performance.
Postprocessing Methods
All these methods provide real-time corrections, eliminating office processing work. However, some applications benefit from postprocessing approaches. For example, the Post Processed Kinematic (PPK) data processing technique commonly supports drone mapping operations. It records raw GNSS data during flight, then processes it after completion using measurements from a nearby base station with a known location. In remote areas or complex environments where signal loss might occur, PPK can improve the yield of accurate positions during missions.
Matching Methods to Your Project Needs
Determining your approach starts by defining your accuracy requirements. If submeter accuracy suffices, SBAS is a cost-effective solution that’s often free and built into professional GNSS receivers. When projects demand centimeter-level precision, RTK or PPP methods may be a better choice. Also consider these factors:
A table titled “Choosing Your Correction Method” that lays out the different accuracies, initialization times, coverage, and internet requirements of various correction methods.
Selecting the right correction method balances accuracy needs, budget, and operational constraints. Carefully evaluating project requirements alongside available infrastructure and service options can help ensure reliable positioning performance while optimizing efficiency and cost.
Expanded GNSS constellation and modern correction techniques have transformed field data collection capabilities for GIS professionals. Understanding these correction methods, as well as their specific strengths and limitations, can empower users to capture the high-accuracy spatial data that their projects demand.
About the author
With a background in electrical and mechanical engineering and over 15 years of experience in mobile data collection, Morgan Zhang has consistently viewed GIS as a complex engineering challenge. As a principal product engineer at Esri, he brings a cross-discipline approach to tackling exciting problems in GIS, like integrating GNSS and other sensors with location-based field applications to create innovative solutions.
Next Article
Bookshelf
Read the next article in this issue
Get the PDF
ArcUser Spring 2026
Read this issue
View the PDF
