arcuser
Make Maps People Want to Look At: Five Design Principles for Cartography
Three separate map images comparing the same stretch of the coast of crater lake with varying typography and symbology.
Appropriately sized text and fonts with open space within and between letters can be more easily read. Familiar symbols and those that look like what they stand for can be more easily understood (A). Symbols and text that are too small are illegible (B). Complex text and symbols need to be larger to be seen and understood. Unfamiliar symbols can confuse map readers and require the use of a legend (C).
Cartographers rely on many design principles when compiling maps and constructing page layouts, whether on-screen or on paper. Five of these design principles form a system for seeing and understanding the relative importance of the content in the map and on the page. Without these primary principles, map-based communication is bound to fail.
Legibility and visual contrast provide the basis for seeing the contents within the map. Figure-ground organization and visual hierarchy lead the map reader to determine the importance of things and ultimately find patterns. And proportion lends aesthetic appeal to the map and its layout.
These five principles are essential in cartography. It’s worth noting that they are not applied in isolation but act complementarily. Together, they help cartographers create maps that successfully communicate geographic information.
1. Legibility
Legibility is the ability to be seen and understood. The size and complexity of text and symbols affect legibility. This becomes an even greater issue if the background is also complex. Readers effortlessly see and understand symbols that are appropriately sized and familiar. Geometric symbols are easier to read at smaller sizes, but their ambiguity often requires clarification in a legend. More complex symbols and text require more space to be legible.
Three separate maps displaying Prince Edward Island with varying degrees of visual contrast.
Although black and white (A) provides the best visual contrast between colors, this is not always the best color choice for maps. When using colors of similar high (B) or low (C) saturation (brightness), the hues (red, green, blue, yellow) must be distinguishable. If not, varying the saturation or value (lightness or darkness) of a color can also create contrast. Line and symbol casings (B) and text masks (B and C) can help as well.
2. Visual Contrast
Visual contrast relates to how map features and page elements contrast with each other and their background. To understand this principle at work, consider your inability to see well in a dark environment. Because not much reflected light reaches your eyes, there is little visual contrast between the objects in your field of vision, and you can’t easily distinguish one object from one another or from its surroundings. Increase the illumination and you’re better able to distinguish between features and their background.
The concept of visual contrast also applies in cartography. Good visual contrast can result in a crisp, clean, clear-looking map. Visual contrast helps emphasize differences, highlight important features, and improve readability. It can be achieved by varying symbol and text sizes and using contrasting colors. The higher the contrast between features, the more some features will stand out (usually those that are bigger, darker, or brighter). Conversely, low visual contrast can be used to promote a more subtle impression, and lower contrast maps can be used as basemaps on which thematic operational layers can be overlaid.
3. Figure-Ground Organization
Figure-ground organization is the spontaneous separation of the primary area of interest in the foreground (the figure) from an amorphous background. Cartographers use this design principle to help readers focus on a specific area of the map. There are many ways to promote figure-ground organization, such as showing the map as a closed form that only includes the figure, or using the techniques illustrated with this map of Botswana (left). Some of the techniques can be used together, as well as other techniques that allow you to highlight your area of interest.
Six separate maps of Botswana depicting multiple figure-ground organization options.
In a map, it is sometimes hard to tell the figure from the ground (A). Showing only the figure (B); adding a drop shadow (C); or using screening (D), illumination (E), or a vignette (F) can help.
4. Visual Hierarchy
Visual hierarchy is the internal graphic organization or structure of the content in a map. Visual hierarchy helps cartographers communicate the relative importance of mapped features through a visual impression that prioritizes or orders the categories of features. This visual layering of information is fundamental to a reader’s ability to understand a map. Correctly applied, visual hierarchy reflects an appropriate intellectual order by graphically emphasizing the most important map features and de-emphasizing those that are less important.
The hierarchical organization for reference maps (those that show the location of a variety of physical and cultural features, such as terrain, roads, boundaries, and settlements) works differently than for thematic maps (those that concentrate on the distribution of a single attribute or the relationship among a few related attributes).
Map of New Plymouth with roads clearly depicted in orange overlaid atop multiple geographical features.
In reference maps, different colors, patterns, and sizes for the text and symbols help distinguish among features on the same layer and between layers. Overlaying one layer onto another provides the subtle separation needed to understand the hierarchy of feature layers. (Courtesy of Land Information New Zealand)
For reference maps, subtle differences order the layers. Often, the order depends on the way layers occur geographically, with physiography on the bottom, followed by hydrography, vegetation, and human-made features, then boundaries and administrative features on top. For thematic maps, reference layers recede to the background, allowing the thematic layer to ascend to a higher visual plane. Labels on the highest visual plane to ensure legibility.
5. Proportion
Map of Pittsburgh displaying vacant housing units with small green simplified house icons. Larger icons indicate more vacant housing units.
When mapping thematic data, the base layer content is kept to a minimum so that the thematic layer lies on the highest visual plane in the hierarchy.
Proportion helps the map and its elements come together as a cohesive whole to form an aesthetically pleasing visualization. Proportion is the relationship between one element and another in the map and on the layout. Design concepts that relate to proportion include symmetry, balance, and harmony.
Three separate maps of Africa depicting people per square mile with light purple dots. Each map features the land and legend oriented differently, to displaying multiple proportion options.
On the first layout (A), the map is positioned at the visual center of the layout, and map elements are arranged in a symmetrical manner to create formal balance. The other two layouts (B and C) are designed with informal balance. The position of elements on the layout can also cause the eye to move in a desired direction, for example, from the title to the map to the other elements on the page.
Balance is the distribution of visual weight within a map or on a layout. The impression of visual balance is controlled by the size, visual weight, and location of the contents in the map and the elements on the layout. Visual balance can be promoted by placing the map figure in the visual center of the layout, which is a point just above the geometric center. This is the point on which the eye first focuses, and it serves as the fulcrum, or balancing point, for the layout. The visual center of the whole image shifts as changes are made to the elements on the layout.
Blank map of the United States colored green, with various generic map elements explained around the edges, with arrows pointing to where these elements might best fit.
Symmetry, balance, and harmony work together to promote good proportion.
When a layout has harmony, the map and its elements have a cohesive arrangement and present a meaningful whole. Harmony can be promoted through alignment and distribution. Alignment positions elements relative to each other (left, center, right, top, bottom). Distribution spaces elements evenly between each other. Both can be employed with objects within elements, such as the parts of a legend, or with a set of related elements—for example, the locator map, text block, and legend in the layout of the map of the US above.
About the author
Aileen Buckley is a cartographer researcher and senior principal GIS engineer at Esri. She works on the ArcGIS Living Atlas of the World team making, writing, and talking about maps. Buckley is also involved in a number of cartographic societies and associations and is the chair of the International Cartographic Association (ICA) Ethics in Cartography Commission.
Next Article
Create New Variables with the Near Me Tool in ArcGIS Experience Builder
Read the next article in this issue
Get the PDF
ArcUser Spring 2026
Read this issue
View the PDF
