ArcGIS Blog
3D Visualization & Analytics
Drone2Map 1.2 is now available for download
By Tony Mason
Drone2Map for ArcGIS version 1.2 is available for download from My Esri and the Drone2Map for ArcGIS Help Site.
This release builds on the themes of ease of use and automation by adding in key features for batch processing, sharing web maps, and increasing the quality of 2D and 3D imagery products.
Here are some of the highlights of the Drone2Map 1.2 release:
  • Run multiple projects in batch mode
  • Redesigned ribbon for better organization and ease of use
  • Ability to open your Drone2Map projects in ArcGIS Pro directly from Drone2Map
  • Ability to change layer symbology in table of contents
  • Level of Detail (LOD) support for 3D Textured Meshes
  • Additional 3D textured mesh settings for better control of your output products
  • Ability to recreate products without re-running initial processing
  • New draw tools for marking up your Drone2Map projects
  • Ability to share your Drone2Map projects as Web Maps to your sharing portal
  • Improved image viewer with integrated image carousel
  • View the processing log in real time to get more fine grained status
  • Support for setting your output spatial reference without defining GCPs
  • Use custom templates directly from create new project page
  • Ability to select image points from the map when using the image properties window
  • Added support for select calibration parameters
  • Improved settings for default application behavior
Share this article
Leave a Reply
