ArcGIS Blog
Analytics
Apps
What's New in Community Analyst (March 2019)
By Jordan Cullen and Praveen Srivastava
The March 2019 update to Community Analyst has arrived! Here are the key highlights of this release:
Better, Professional Infographics at Your Fingertips
Use a brand-new set of seven visually stunning starter infographic templates to summarize your data and analysis. Easily customize them to reflect the logo, branding, and variables of your choice. Whether you are trying to understand Employment Overview, Office Market Profile, or Health Statistics for an area, the new templates have you covered.
Image with three thumbnails of new infographic templates available in the March 2019 release of ArcGIS Community Analyst.
Three of the seven new infographic templates available in the March 2019 release of ArcGIS Community Analyst - Office Market Profile, Health Care and Insurance Statistics, and Commute Profile.
Get More Out of Comparison Reports
Interactively compare sites easier than ever using informative benchmark tables, beautiful charts, and more in the new Comparison Reports workflow.
The old Comparison Reports workflow has been removed with this release, but there’s no need to worry! Its replacement, the new Comparison Reports workflow, is already available right inside the application. The new workflow gives you all the old Comparison Report features and so much more. Learn more about how to migrate to New Comparison Reports.
Bar chart with green and white vertical bars showing the new Comparison Reports.
Mouse over any of the bars and lines to view a popup with the variable name, value and variance from the defined benchmark site with the new Comparison Reports in ArcGIS Business Analyst Web App.
Access Crime Data for Reporting
Use a new Esri Crime Summary report that helps you understand crime statistics for seven major categories of personal and property crime. You can now use the crime data in custom reports, infographics, and comparison reports to classify crimes by local demographics and type of incident.
An infographic and custom report with crime data as a highlighted variable.
Access crime data in your custom reports and infographics in ArcGIS Community Analyst.
Add Nearby Location Counts and Summaries
ArcGIS C0mmunity Analyst users can now summarize attribute values in Nearby tables. When running infographics with a Nearby table, click the gear icon, choose the attributes that you want to summarize, and see the results added at the bottom of the table. Optionally, you can now choose to display the Nearby table as a summary count in its own panel.
Example of nearby attributes for coffee shops in custom infographics in Community Analyst.
Display nearby attributes in your infographics using ArcGIS Community Analyst.
Modern Symbology for Your Mapping Needs
Hundreds of new map markers are now available to symbolize locations the way you want. Start with vector graphics and color them to present locations with the best visualization.
An example map using a black and gray basemap with green coffee cups used as the symbology for coffee shops across the U.S.
In this Business and Facilities Search, we've symbolized coffee shops across the United States with a coffee cup, one of many new symbols in ArcGIS Community Analyst.
Combine Dot Density Visualization with Color-Coded Maps
Users now have a new option to display a dot density map with a color-coded background. You can view one variable represented in the dot density style in the foreground and a second variable with a color ramp background map.  For example, users can show the total population using dot density mapping shaded by a color-coded background map of median household income.
Color coded map of the U.S. with dot density overlaid.
Users can now visualize dot density maps over their color-coded maps in ArcGIS Community Analyst.
Use Top Consumer Segments for Canada
Determine the top three consumer segments for any area in Canada using the PRIZM5 segmentation data. Simply add the PRIZM5 segments panel in your infographics and run it for any area.
A custom infographic defining top consumer segments for an area in Canada using PRIZM5 data.
Determine top consumer segments for any area in Canada using PRIZM5 data in ArcGIS Community Analyst.
Use Web Layers Directly in Reporting Workflows
Bring in location layers from ArcGIS and run reports, infographics, and more without having to convert them into sites. With the new Setup layer option, you can now use services already published in ArcGIS in Suitability Analysis, Infographics and reports without the need to duplicate locations. The Setup layer feature also allows pre-filtering by attribute and by map extent.
A black and gray basemap with a web layer from ArcGIS Online referenced in red and blue.
Use your web layers from ArcGIS directly in your workflows in Community Analyst.
Data Update
With this release of ArcGIS Community Analyst, we have very exciting updates to our data that is now available for users:
ArcGIS Community Analyst now has new advanced data for the Netherlands sourced from 4Orange. Working with Esri Netherlands, we are releasing a new, advanced dataset summarizing socioeconomic, life stage, and personal interest data for Dutch consumers. This data, available at the five-digit postal code level, will provide additional attributes covering:
  • Demographic and Socioeconomic topics: Households, Population, Age, Education, Household Size, Stage of Life, Habitation, Heating Fuel, Home Value, Housing Type, Year Built, Income, Industry, Profession, and Marital Status.
  • Behavioral topics: Alcohol Consumption, Automotive, Charity, Cultural Engagements, Sports, Internet, Social Media, TV, Pets, Travel, Personal Viewpoints, Buying Behavior, Internet Shopping, Finances, Insurances, Retirement, and Mobile Phones.
  • Segmentation: Personicx Lifestyle Segments.
U.S. data updates for businesses locations and DMM major shopping centers to January 2019, Kalibrate traffic data to Q4 2018, and Crime data to November 2018.
Michael-Bauer Research data update to 2018 vintage for 18 countries including New Zealand, Panama, United Arab Emirates, Venezuela, Qatar, Oman, and more.
Stock image showing an area of individuals in black and gray with a targeted area in color.
Exciting updates to the data in ArcGIS Community Analyst is now available for users!
We’re so happy to share this Q1 2019 release of ArcGIS Community Analyst with you. Below you can find some links for Community Analyst that you may find useful.
Share this article
