Earth’s surface is constantly changing. Forest disturbances caused by timber harvesting, wildfires, and other environmental factors can have lasting effects on ecosystems. Understanding when and where these changes occur, and how landscapes recover over time, is essential for monitoring forest health and managing natural resources.
Time-series satellite imagery provides a powerful way to monitor these changes. By analyzing imagery collected over multiple decades, you can identify disturbance and recovery patterns, measure the duration of changes, and better understand how landscapes evolve.
At this year’s Developer and Technology Summit plenary, Hong Xu demonstrates how you can use Landsat imagery and the Landsat-based detection of trends in disturbance and recovery (LandTrendr) algorithm to analyze forest cover changes over time. Using ArcGIS Notebooks and multidimensional raster analysis capabilities, you can analyze decades of satellite observations to identify when forest disturbances occur, characterize their magnitude, and track landscape recovery. This workflow brings together time-series imagery and advanced change detection to uncover patterns of forest change across large geographic areas.
Preparing time-series imagery for analysis
For the demonstration, Hong Xu uses 80 Landsat scenes collected over a 34-year period, beginning in 1984, covering Oregon’s West Cascades ecoregion. Using ArcGIS Notebooks, she works with the Landsat imagery to prepare the data for time-series analysis.
The scenes are combined into a multidimensional raster, which organizes imagery along a time dimension. Rather than analyzing each image independently, you can use a multidimensional raster to examine how each pixel’s spectral characteristics change across multiple observations. This provides the foundation for identifying patterns of disturbance and recovery over time.
The multidimensional raster is then used to generate the normalized burn ratio (NBR), a spectral index calculated using the near-infrared (NIR) and shortwave-infrared (SWIR) bands. NBR is commonly used to identify burned forest areas and assess burn severity by highlighting changes in vegetation and surface conditions.
Analyzing forest changes with LandTrendr
While individual satellite images provide snapshots of forest conditions, understanding when disturbances occur and how landscapes recover requires analyzing observations across time.
LandTrendr addresses this challenge by analyzing each pixel’s spectral trajectory across the time series. The algorithm segments each pixel’s history into distinct periods, identifying intervals of relative stability, disturbance, and recovery.
In the demonstration, Hong Xu uses the Analyze Changes Using LandTrendr raster analytic function to process the NBR multidimensional raster. The function evaluates changes in pixel values over time and generates a change-analysis raster containing segmented time-series trajectories.
This output lets you examine when changes occurred, how substantial they were, and how forest conditions evolved after a disturbance.
Mapping forest disturbance and recovery
Once the LandTrendr change analysis raster is generated, you can use it to extract additional information about forest disturbance and recovery.
Hong Xu uses the Detect Change raster analytic function with the LandTrendr output to generate a raster containing pixel-level change information. The resulting map highlights areas with logging activity in recent years, with darker shades representing more recent activity.
By examining the spatial distribution of these changes, analysts can identify areas of potential timber harvesting and investigate patterns across the study area. Combined with additional information, such as land management records and field observations, this analysis can support efforts to monitor timber harvesting and investigate potential unauthorized logging.
The same Detect Change raster analytic function can also be used to generate a recovery duration map. This provides another perspective on forest change by showing how long forest areas take to recover following a disturbance.
In the demonstration, the recovery duration map reveals that most forest areas in the West Cascades ecoregion require, on average, more than 10 years to recover. This information provides valuable context for understanding the longer-term effects of forest disturbances and identifying differences in recovery patterns across the landscape.
Visualizing and exploring changes over time
The final step is to classify the time-series imagery and visualize the results. Hong Xu uses the LandTrendr change analysis raster to classify the imagery and then visualizes the output as a multidimensional raster in ArcGIS Pro.
ArcGIS Pro’s multidimensional visualization capabilities let you explore results across time periods and examine the spatial distribution of changes. This makes it easier to interpret patterns of forest disturbance and recovery and understand how the landscape has evolved throughout the study period.
Explore forest changes with LandTrendr
Time-series imagery provides a valuable resource for understanding how landscapes evolve. By combining Landsat imagery, multidimensional raster analysis, and the LandTrendr algorithm, you can identify forest disturbances, examine logging patterns, and measure recovery over time.
These capabilities extend beyond forest monitoring. Similar approaches can support a variety of applications, including wildfire impact assessment, vegetation monitoring, and environmental change analysis.
To learn more about analyzing time-series imagery and detecting changes using LandTrendr, see the ArcGIS Pro documentation.
