ArcGIS StoryMaps
Using Story Map autoplay mode
Note: This blog covers the classic Esri Story Maps. Story authors are encouraged to use the new ArcGIS StoryMaps to create stories. However, Esri will continue to maintain the classic templates for your use. For more information, see the Product road map.
Story Maps normally require user interaction; the viewer must click or scroll to advance to the next section, entry, or tour point. But many Story Maps support autoplay mode, where the story advances automatically, and loops when finished.
Autoplay mode is ideal when you want to use a story map in a public kiosk, such as in a visitor center or museum exhibit. It’s also useful if you are displaying live data and want to cycle through maps to show the latest information, such as in a command center or emergency operations center.
The following Story Maps support autoplay:
Using autoplay
To autoplay any of the Story Map apps listed above, simply add &autoplay to the Story Map URL. For example, this URL opens the story map without autoplay:
http://www.arcgis.com/apps/MapJournal/index.html?appid=102cce4590a34b478ffe0909e04a7692
This URL opens the story map in autoplay mode:
http://www.arcgis.com/apps/MapJournal/index.html?appid=102cce4590a34b478ffe0909e04a7692&autoplay
If the Story Map includes a Share link, you can also enable autoplay by clicking the share link
and checking the box.
Checking the box will add &autoplay to both the short link and the embed HTML.
Autoplay control
When autoplay is enabled, the autoplay control appears on the Story Map. Click to pause or play, or grab the slider to adjust the time interval.
When paused, you can interact with the Story Map normally, then click play to resume.
See Autoplay in the Story Maps FAQ for more information.
This post was originally published on March 1, 2016, and has been updated.
About the author
Corporate technology evangelist and advocate at Esri, focusing on ways to broaden access to geographic information and helping customers succeed with the ArcGIS system. On a good day I'm making a map, on a great day I'm on one. Email bszukalski@esri.com or connect on LinkedIn (https://www.linkedin.com/in/bernszukalski/).
Connect:
Next Article
Time-saving tips for managing members in ArcGIS Online
Read this article
