The new Gallery template from ArcGIS Instant Apps improves the experience of sharing a group of maps and layers to an audience. Combining a modern look and feel with updated settings and features, Gallery is the best way to present content from a group in a filterable and searchable grid or list. You might be familiar with our longstanding Category Gallery template. Category Gallery has been the go-to solution for sharing content from a group in an easy-to-use web app interface for some time. The new Gallery template offers the same reliable features and more.
At the June 2026 ArcGIS Online release, the Category Gallery template will be retired. Any existing apps you have created using Category Gallery will continue to work and be configurable, but it will use the updated app code of the new Gallery template. This will also mark the end of Category Gallery being an available template to choose from when creating new apps using ArcGIS Instant Apps. Moving forward, please check out the new Gallery template and begin taking advantage of its updated UI, feature enhancements, and configuration updates as it will soon be the replacement solution for Category Gallery.
Gallery is built to make sharing and interacting with content simple. Use it to showcase items from a group in a filterable and searchable grid or list and present a collection of items that offer app users the ability to view, open, and explore all in one place. Gallery offers several different ways to filter content in the app using the filter panel, such as by category, item type, date created or modified, tags, and more. The category filter can be configured to use group categories or organization categories. A setting in the configuration lets the app creator decide which one to leverage in their app.
The Cover page and Introduction window have been added to Gallery to offer a means of introducing your app to your audience. On the About > App introduction tab of the configuration, enable “Cover page or introduction window” and then use the toggle to choose which app introduction method best suits your purpose.
The app configuration offers several key settings beyond filtering, such as default layout (grid or list), sign in button, and the ability to open content externally from the app in the ArcGIS Online Map Viewer or Scene Viewer. Enable the “Open in Map Viewer or Scene Viewer” setting in Interactivity > Item card display to make this the main opening action on map, scene, and layer item cards. If this setting is disabled, only the app’s built-in viewers will be used to display these items.
Using the “View in map” or “View in scene” options will open the item using the built-in viewers. A full take-over appears that displays the map, scene, or layer overtop a basemap along with basic mapping tools that are customizable in the configuration. Use the settings on the Interactivity > Map section of the config to choose which tools are offered and use the configuration’s Position Manager to determine where they are placed in the layout. You can also choose the default basemap to use when viewing layer item types. When an app viewer is finished exploring, the “X” at the top right will dismiss the built-in viewer and return to the page of items.
The configuration also lets the app creator determine which details are exposed on the item cards. On the Interactivity > Item card display tab of the configuration, decide to expose and display details such as item type, owner info, date, item options menu, and the item’s summary text. New with this release is the ability to disable the item’s title using the “Item title” setting. The app creator now has full control over showing or hiding every single informational element on the item cards to achieve the desired look. For example, disable all settings on this panel to offer a clean and simplistic layout of only the item thumbnail images in a grid (when using Grid view).
Display items in your app using Grid or List view. Each view displays the same information and items but in different layouts that can both be offered in the app. Use the “Default content layout” setting to choose which view your app displays in on load. Disable the new “Content layout toggle” setting if you would like to restrict the app to only displaying content in one of the views. These settings and more are found on the Theme & Layout > Gallery theme & layout tab of the configuration.
Enable the Share tool in your app so that app viewers can share it with others. The Share tool preserves any filters that are applied using URL parameters so that they can share exactly what they see. When filters are applied in the app, they are represented as elements in the top right near the Share tool.
As you can see, the new Gallery template offers all of the same reliable functionality as Category Gallery for displaying, filtering, exploring, and sharing content from a group, but it also comes with more. Find the Gallery template on the Create tab of the Instant Apps home page to create your first app and take advantage of this quick to configure experience of sharing your content items in a modernized layout. And be on the lookout for future feature enhancements as Gallery leads the way as the go-to app builder solution for displaying items from a group in a filterable grid or list.
Welcome to Minecraft Gallery where you can’t set the card size, number of cards per row, or even device responsive views! Means for desktop users with anything nearing a modern monitor (aka last 20 years) will be faced with an awful looking interface.
