ArcGIS Blog
Mapping
ArcGIS Experience Builder
Exploring Coordinate Conversion in ArcGIS Experience Builder
By Suba Krishnan
The Coordinate Conversion widget in ArcGIS Experience Builder allows users to capture, convert, and share coordinates across different coordinate systems and notation formats. Users can obtain coordinates by selecting a location on the map or entering known coordinates, making it easier to work with location information across different workflows.
In this blog, we’ll explore the widget’s key capabilities and how to use them, followed by the latest enhancements introduced with the November 2026 update to ArcGIS Online.
Explore Coordinate Conversion
The Coordinate Conversion widget supports multiple coordinate notation formats, including Decimal Degrees (DD), Degrees Minutes Seconds (DMS), Universal Transverse Mercator (UTM), and Military Grid Reference System (MGRS), among others.
App authors can configure the coordinate notation formats available in the widget based on their needs. At runtime, users can select a location on the map or enter known coordinates or an address to locate a specific position. They can choose the input coordinate format from a dropdown menu accessed through the settings button.
Users can also view the same location in multiple output coordinate formats without manually converting values. They can add or remove output formats, edit their labels, and display newly added formats at the top of the list. Coordinate values can be copied for use in other applications.
This flexibility makes it easier to work with coordinate information across different mapping and location-based workflows.
What’s new in Coordinate Conversion
With the November 2026 update to ArcGIS Online, the Coordinate Conversion widget introduces two enhancements that improve how users work with coordinates and addresses:
  1. Consistent coordinate precision: Configure a fixed number of decimal places for coordinate values, independent of the map’s zoom level.
  2. Improved address results: Return a point address instead of an address range when identifying a location on the map.
Let’s take a closer look at each enhancement.
Previously, the number of decimal places displayed for coordinate values could change based on the map’s zoom level. With this enhancement, app authors can configure a fixed number of decimal places for coordinates, ensuring that values are displayed consistently regardless of how far users zoom in or out on the map.
This is particularly useful for workflows that require consistent coordinate precision when identifying, recording, or sharing locations. For example, an app author can set a fixed number of decimal places between 0 and 4 in the app configuration, maintaining the same displayed precision as users navigate the map.
The Coordinate Conversion widget now supports returning a point address instead of an address range when identifying a location on the map.
Previously, reverse geocoding could return an address range associated with a street segment rather than a specific address. With this enhancement, the widget can return a point address when one is available, providing more specific address information for the selected location.
For example, instead of returning an address range such as “100–198 Main Street,” the widget can return a specific address such as “150 Main Street,” when supported by the geocoding service.
This improvement is useful when users need more specific address information while identifying locations or sharing location details.
Looking ahead
Try out the Coordinate Conversion widget in ArcGIS Experience Builder and explore these enhancements in your applications. If you have questions or feedback, feel free to reach out to me directly or through the Esri Community.
Share this article
Leave a Reply
