ArcGIS Blog
Field Operations
ArcGIS Field Maps
From Marks on the Ground to Mapped Assets: Utility Locating with ArcGIS Field Maps
By Sarah Saint-Ruth
Knowing where underground infrastructure is located is critical to keeping people safe, preventing costly utility strikes, and maintaining reliable networks.
Yet locating and mapping are often separate activities. Crews locate and mark underground assets, while updating the GIS can require a separate survey or additional processing.
With the November 2026 release, ArcGIS Field Maps brings these workflows together with support for RTK-enabled utility line locators. These devices combine utility locating with high-accuracy GNSS positioning, allowing crews to locate buried pipes and cables while capturing their position, depth, and other locate information directly in Field Maps.
Capture underground utilities as you locate them
In the field, Field Maps introduces a new capture experience designed specifically for utility locating. The mobile worker starts capture in Field Maps and selects the utility type if there is more than one, such as electric, gas, water, or communications.
From there, capture moves to the locator. The worker can put the phone or tablet away and focus on locating the underground utility. As they move along the utility, positions captured from the locator add vertices to the line being mapped in Field Maps.
Line Locate Experience in Field Maps
ArcGIS Field Maps capturing an underground utility line and locate measurements from a connected line locator.
Each position also creates a related locate point, automatically recording the GNSS and locator information associated with that measurement. This can include position accuracy, depth, frequency, signal strength, locate mode, current, utility direction, and the locator used.
Line Locator Metadata
Getting Started
Before you start collecting underground utilities in Field Maps, you’ll need:
  • A supported RTK-capable utility line locator – these include Radiodetection and Subsite locators, with Vivax-Metrotech locators available in beta
  • A Line Locate map created and configured from the provided template in Field Maps Designer
  • ArcGIS Field Maps and the locator manufacturer’s companion app installed and configured
Similar to GNSS receivers, the utility line locator is configured as a location provider in Field Maps. The manufacturer’s companion app maintains the connection to the locator and the correction source used to provide centimeter-level positioning.
Configure Line Locators with Location Profiles using Subsite Companion application and Field Maps
Line Locate Template
To simplify the mapping setup, Field Maps Designer includes a new Line Locate map template.
Line Locate Template with Feature Templates
The template creates two related layers:
  • Locate Lines is the primary layer used to map the underground utility and capture information such as utility type, ticket number, and photos.
  • Locate Points are created automatically for each position captured from the locator and store the GNSS and locator metadata associated with that measurement.
There is also an ArcGIS Pro project available here which can be used to publish the Line Locate map to ArcGIS Enterprise and ArcGIS Online.
Locate Lines Layer
The Locate Lines layer represents the underground utility being mapped and is the primary layer the mobile worker interacts with during capture.
It includes the following attributes:
Field Name and Type Values
Label Code
Locate type esrilocate_line_type – string field, 20 character length Communication communication
Electric electric
Gas gas
Proposed excavation proposed
Reclaimed water reclaimed_water
Sewer sewer
Temporary temporary
Water Water
Ticket number ticket_number – string field, 50 character length
Locate Points layer
As positions are captured from the locator, Field Maps automatically creates related Locate Points along the line. Each point preserves the GNSS information and locator measurements associated with that individual capture.
Name Code
Locate type esrilocate_point_type – string field, 20 character length Communication communication
Electric electric
Gas gas
Sewer sewer
Temporary temporary
Water Water
Antenna mode esrilocate_antenna_mode, string field, 20 characters Potential values include:
Broad Broad + arrows Guidance Left Right auto Left Right manual Null Omni peak Omni broad Peak Peak + arrows Peak + null
Left/Right/Null arrows esrilocate_arrows, small integer field Range domain (-100 to 100)
Direction of utility (°)
Units are Degrees Alignment angle of a locator to the target line in degrees
esrilocate_utility_compass, small integer field 0-360
Current mA
Units are milliamps
esrilocate_current, double field
Direction of current esrilocate_direction_of_current, small integer field None 0
Forward 1
Reverse 2
Unknown 3
Custom attributes esrilocate_custom_attributes, string field, 2000 characters
Depth (m)
Units are meters
esrilocate_depth, double field
Frequency (Hz) esrilocate_frequency, integer field
Gain (dB) esrilocate_gain, small integer field
Locate mode esrilocate_locate_mode, string field, 20 characters Potential values include:
Active, Power, Radio, Cathodic, CATV, RFMarker, Sonde
Locator device esrilocate_locator, string field, 50 characters
Locate line GUID locate_line_guid, GUID
Log date
Unit are ms since Unix epoch
esrilocate_log_datetime, date field
Signal strength (%) esrilocate_signal_strength_per, small integer field Range domain (0-100)
Marker type
Populated when using a locator that supports capture of a marker and a marker is found.
esrilocate_marker_type, small integer field Power (Red) | 169.8kHz 0
Water (Blue) | 145.7kHz 1
Euro power (Blue/Red) | 134.0kHz 2
Wastewater (Green) | 121.6kHz 3
Telecom (Orange) | 101.4kHz 4
Gas (Yellow) | 83.0kHz 5
CATV and communications (Black/Orange) | 77.0kHz 6
General and Reclaimed water (Purple) | 66.35kHz 7
French power (Natural) | 40.0kHz 8
Configure for Workflow
The Line Locate map provides a starting point that can be adapted to your organization’s locate workflow. Using Field Maps Designer, map authors can:
  • Add additional fields needed for capture, using the Locate line layer for user-entered values, default values, and form calculations. Locate point layer fields can use default values and form calculations, but cannot accept user-entered values during collection.
  • Customize utility types and feature templates, removing those that aren’t relevant or setting default values to simplify capture.
  • Add existing utility and asset layers to give crews context while they work or capture additional above ground assets.
  • Use calculations to derive additional information from captured locate data.
  • Configure collection settings, including whether manual locations are permitted when appropriate.
Make every locate improve the system of record
By capturing accurate location and locate information directly in ArcGIS, every locate becomes an opportunity to improve the organization’s record of what’s underground. There’s more we want to explore, including through a new ArcGIS Solution planned for 2027. We’d love to hear how you’re using this integration and what you’d like to see next. Share your feedback on Esri Community Ideas.
Share this article
Leave a Reply
