ArcGIS Blog
Mapping
ArcGIS Instant Apps
Atlas: One template, many applications
By Krista McPherson
The Atlas Instant Apps template allows app authors to showcase a collection of maps and layers and includes lightweight tools to discover, view, and explore. Atlas is the underlying template for National Geographic’s new MapMaker, an app created to promote geographic awareness and support lessons in K-12 education. In addition to being an educational tool, the Atlas template provides a flexible and configurable way to create an interactive mapping experience for any audience.
Atlas app with many layers
Gif image demonstrated an Atlas Instant Apps template
This Climate Resilience Interventions Atlas app contains many layers and includes the Add layers option set to open when the app loads, allowing you to add layers of interest on top of the default basemap. You can change the basemap and use Map layers to compare data using swipe and transparency. Once you add layers, you can save the map to your content in ArcGIS Online.
Atlas app with many maps
This California Wildfire Risk Assessment app uses several maps related to the topic of fire risk and impact in California. The app is set to start with the California Fire Hazard Severity map and the Map layers panel open. You can open a variety of maps and view tables and descriptions using map layers to better understand risk factors and impacts. This app allows you to add a sketch to the map and capture a screenshot that can be exported as a JPG, PNG, or PDF.
Atlas apps with many maps and many layers
The Blueprint Denver app allows you to plan project maps and layers for Denver, Colorado. You can add or remove layers and open maps to gain a better understanding of the city’s future. The legend tool is enabled to help you interpret the map data, and the measure tool can be used to assess distances between roads and project locations.
This Community Garden Suitability Analysis app contains maps and layers related to zoning and population in Boston, Massachusetts. You can explore the data to determine which communities and neighborhoods could most benefit from a community garden. This app has the 3D tool enabled, which allows you to add a dimension to the map view.
Explore these examples of Atlas and other Instant Apps templates in the Instant Apps Sample Gallery. Share your feedback and ideas in the Instant Apps section of Esri Community.
Share this article
Leave a Reply
