ArcGIS Blog
ArcGIS Maps SDK for JavaScript
Using $arcgis.import(): Simplify Module Loading in ArcGIS Maps SDK for JavaScript CDN Apps
By Manoja Gadde
The JavaScript module landscape continues to evolve rapidly. While AMD served CDN-based vanilla JavaScript applications well, ES modules are now considered the standard for web-based applications. For example, TypeScript has announced plans to deprecate AMD output in the future, signaling this broader industry trend.
For developers using the ArcGIS Maps SDK for JavaScript via CDN, this shift brings both opportunities and important considerations.
With version 4.32 of the Javascript Maps SDK, we introduced $arcgis.import(), a promise-based API for loading SDK modules in applications built with the CDN. When compared to callback-based AMD approaches, it provides a cleaner syntax for implementing lazy loading patterns like dynamic and conditional module loading. It works seamlessly with modern async/await patterns while maintaining full compatibility with existing AMD-based applications. It is also designed to transparently support ES modules in the future with zero code changes required.
For new CDN-based applications, we recommend using $arcgis.import() for module loading. While require() will continue to be supported, $arcgis.import() is the preferred and future facing approach.
In this post, you’ll learn:
  • How $arcgis.import() compares to traditional require() patterns
  • When and why you should adopt this approach
  • Practical patterns for dynamic and conditional module loading
  • How this prepares your codebase for future ES module support
Current Module Loading Patterns
The JavaScript Maps SDK supports three primary consumption patterns:
NPM + Build Tools (ESM)
You can install @arcgis/core via NPM and use standard ES module syntax with bundlers like Vite, Webpack, or Rollup. Modern frameworks like React, Vue, Svelte, and Angular follow this path, which is already fully ESM.
import WebMap from "@arcgis/core/WebMap.js";
import FeatureLayer from "@arcgis/core/layers/FeatureLayer.js";
CDN with require()
Load the SDK directly from the Esri CDN using the legacy AMD format and the require() function. This continues to be supported but has limitations when it comes to modern JavaScript workflows, especially around code-splitting and dynamic import patterns.
<script src="https://js.arcgis.com/4.33/"></script>
<script>
  require(["esri/WebMap", "esri/layers/FeatureLayer"], function (WebMap, FeatureLayer) {
    const map = new WebMap({ basemap: "topo-vector" });
    const layer = new FeatureLayer({ url: "https://services.arcgis.com/P3ePLMYs2RVChkJx/arcgis/rest/services/ACS_Housing_Tenure_by_Heating_Fuel_Boundaries/FeatureServer/1" });
</script>
If you’re developing your application using the AMD modules or an AMD build tool, it is recommended to migrate to using $arcgis.import() or ES modules and modern build tools.  See our guide to get started.
CDN with $arcgis.import
$arcgis.import()is a CDN-hosted only, a promise-based module loader built directly into the SDK. It accepts a single module, or an array of module paths and returns a promise that resolves to the loaded modules.
<script type="module">
  const [Map, FeatureLayer] = await $arcgis.import([
    "@arcgis/core/Map.js",
  const map = new Map({ basemap: "topo-vector" });
</script>
Note that it uses the @arcgis/core/ ES modules path format instead of the traditional esri/ AMD paths.
Unlike the traditional AMD-based apps that rely on global require() function, $arcgis.import(), does not need any global imports. It works seamlessly in modern module environments.
Basic Usage Patterns
Load a single module:
const Graphic = await $arcgis.import("@arcgis/core/Graphic.js");
const graphic = new Graphic({ /* ... */ });
</script>
Load multiple modules together:
const [Map, Multipoint, FeatureLayer] = await $arcgis.import([
 "@arcgis/core/geometry/Multipoint.js",
</script>
Lazy Loading Scenarios
$arcgis.import() provides cleaner syntax for dynamic and conditional module loading patterns compared to the callback-based AMD approaches. This level of flexibility is hard to achieve with traditional AMD require blocks.
Dynamic module loading ensures that the module is only loaded when needed, improving the initial loading performance of the application. In this example, the FeatureLayer module is loaded dynamically when the user clicks a button.
  document.getElementById("loadButton").addEventListener("click", async () => {
    const FeatureLayer = await $arcgis.import("@arcgis/core/layers/FeatureLayer.js");
    const layer = new FeatureLayer({ url: "https://services.arcgis.com/..." });
    map.add(layer);
</script>
Conditional module loading enables different modules based on runtime conditions. For example, loading different layers based on map zoom level:
  const Map = await $arcgis.import("@arcgis/core/Map.js");
  view.watch("zoom", async (zoom) => {
    if (zoom > 10) {
      // Load city-level layer
    } else {
      const GraphicsLayer = await $arcgis.import("@arcgis/core/layers/GraphicsLayer.js");
      // Load country-level layer
</script>
Migration Path
If you’re using the CDN with require(), now is a good time to start using $arcgis.import(). It coexists with require(), so you can migrate incrementally.
The migration is straightforward:
  • Replace require() callbacks with await $arcgis.import()
  • Use array destructuring for loaded modules
  • Add type="module" to script tags
  • Replace error callbacks with try/catch blocks
Next steps
  • Try out $arcgis.import() in your CDN-based apps
  • Use it to load modules dynamically based on user interaction or route changes
  • Check out our updated samples that demonstrate this pattern
Looking Forward
Whether you’re maintaining a legacy application or building the next big civic mapping tool, $arcgis.import() bridges current AMD patterns with future ES module support.
Let us know how you’re using $arcgis.import() in your apps and what you’d like to see next
Further reading
Share this article
3 responses to “Using $arcgis.import(): Simplify Module Loading in ArcGIS Maps SDK for JavaScript CDN Apps”
  1. Hi Antonio,
    For reference, here’s a sample repository demonstrating this setup: https://github.com/manugadde/arcgis-web-components-demoes/tree/main/cdn.
    The sample shows how to load JS SDK Components via CDN using $arcgis.import. It works locally and can serve as a starting point for testing or building your own project.
    If you’re still encountering a CORS error, would you like to share your application so we can take a closer look?
    Regards
    Manoja Gadde
    Product Engineer – ArcGIS Maps SDK for JavaScript
Leave a Reply
