ArcNews
ArcGIS Maps SDK for JavaScript
November 2026
JavaScript Maps SDK 101
article image
Some GIS professionals use robust developer tools every day. Others work primarily with options that entail little to no coding and don’t require experience with dedicated developer software. But tools like ArcGIS Maps SDK for JavaScript can bring extra flexibility, scalability, and power to your mapping apps.
ArcGIS Maps SDKs are a family of developer tools designed to build mapping and spatial analysis apps across platforms. Along with software development kits (SDKs) for web (JavaScript), the suite includes native apps (.NET, Flutter, Swift, Kotlin, and Qt) and game engines (Unity and Unreal Engine).
So what is JavaScript Maps SDK, and how can developers and organizations use it to build custom, location‑aware apps?
Map of Los Angeles with green areas highlighting forested and shrubby land cover. A sidebar titled "Mountain Lions of Los Angeles" shows "Land cover" selected, indicating these areas are preferred habitat for mountain lions and their prey.
An interactive web app built with JavaScript Maps SDK analyzes mountain lion habitat suitability using client-side raster analysis and imagery.
What Is JavaScript Maps SDK?
JavaScript Maps SDK is Esri’s premium tool for building custom, interactive web mapping apps. It enables developers to create rich 2D and 3D experiences that visualize, analyze, and edit spatial data directly in a browser.
Esri uses it to build web apps such as ArcGIS Experience Builder, ArcGIS Instant Apps, and ArcGIS Dashboards. GIS practitioners also use it to create their own web-based apps.
The SDK is built around two complementary elements:
  • The core API—This is the programmatic foundation for working with maps, layers, geometry, rendering, and analysis. It gives developers fine‑grained control over app behavior through JavaScript classes, methods, events, and data models. The API enables highly customized workflows such as advanced visualization, client‑side analysis, feature editing, and integration with other systems, making it ideal for developers who need flexibility and control.
  • Web components—The SDK also includes standards-based, reusable web components that can be used to incorporate maps, charts, UI elements, and AI into web mapping apps with minimal code. These components work with plain JavaScript as well as modern frameworks such as React, Angular, and Vue. Web components accelerate development by providing ready‑to‑use building blocks that follow accessibility and design best practices, allowing teams to focus more on solving problems and less on rebuilding common UI patterns.
Together, the core API and web components let developers choose between deep customization and rapid development or combine both approaches in the same app.
What Can JavaScript Maps SDK Do for Me?
The SDK offers several key benefits for GIS app developers:
  • 2D and 3D visualization—Create high‑performance 2D and 3D maps that can handle large and complex datasets in a browser.
  • Fast client‑side analysis—Perform querying, filtering, measurement, and spatial analysis directly in the web app.
  • Developer resources—Extensive documentation, tutorials, and samples help developers get started quickly and follow best practices.
  • Ecosystem integration—Seamless connection to ArcGIS Online, ArcGIS Enterprise, and ArcGIS Location Platform ensures access to authoritative data and services.
  • Scalability and flexibility—The SDK can be used for simple apps as well as enterprise solutions.
Screenshot of a web app displaying hiking trails in the Swiss National Park. A left panel contains filters for trail name, difficulty, and other options.
This interactive hiking map of Swiss National Park, built with JavaScript Maps SDK, highlights trails, terrain, and routes with filters for difficulty, status, and elevation.
How Do I Use JavaScript Maps SDK?
You can add JavaScript Maps SDK to your apps in two primary ways:
  • Content delivery network—A content delivery network (CDN) hosts and delivers JavaScript files, libraries, and frameworks within a user’s web browser, so you don’t have to host these yourself. JavaScript Maps SDK can be loaded directly into an HTML page using <script> and <link> tags, adding the core API library, all component packages, and the CSS to your app. This approach is ideal for learning, developing quick prototypes, or creating lightweight apps where minimal setup is preferred.
  • npm—Developers can install the SDK as a package in their project and integrate it with modern build tools and frameworks through npm, JavaScript’s default package manager. This method is best suited for production apps that require structured code bases, version control, and optimized builds.
Both options deliver the same capabilities. The choice depends on workflow, not functionality.
While a CDN or npm determines how to access the SDK code, access to maps, data, and services is controlled by a foundational ArcGIS account. Apps built with JavaScript Maps SDK connect to ArcGIS through ArcGIS Online, ArcGIS Enterprise, and ArcGIS Location Platform, Esri’s cloud-based platform as a service (PaaS) with a pay-as-you-go option for location services. Apps using Location Platform start with a free tier and incur usage-based charges as consumption scales.
Custom web apps built or deployed using JavaScript Maps SDK must be licensed through one of these options. For ArcGIS Online and ArcGIS Enterprise users, JavaScript Maps SDK is licensed via user types.
Screenshot of the ArcGIS Maps SDK for JavaScript references page, showing a navigation sidebar and a main area with cards for Map components, Core API, and AI components.
The JavaScript Maps SDK reference hub helps developers access APIs and web components for building interactive mapping and data‑driven web apps.
When Should I Use JavaScript Maps SDK?
JavaScript Maps SDK works best for scenarios in which data and location drive decisions, meaning it can be instrumental in a wide range of environments. Building interactive parcel and zoning viewers; utility network and outage management apps; large-scale 2D and 3D city and infrastructure visualizations; real-time operational dashboards; situational awareness apps for planning and emergency response—all of these are perfect scenarios for the SDK’s capabilities. Any organization that needs to visualize, analyze, or interact with location data on the web can take advantage of JavaScript Maps SDK.
JavaScript Maps SDK is an invaluable tool for bringing location intelligence to custom web apps. By enabling flexible, secure, and scalable web experiences, the SDK helps you transform location data into insight and impact.
Share this article
