arcuser
How ModelBuilder Can Streamline Your GIS Workflows
Every GIS professional faces repetitive tasks that consume valuable time. ModelBuilder, the visual programming language included with ArcGIS Pro, helps automate workflows to run efficiently and consistently. Models function as workflow maps with built-in directionality, using visual elements to communicate process status. When designed for reuse, they become powerful tools for conducting sophisticated analyses and completing geoprocessing tasks faster.
The good news is that if you’re interested in using ModelBuilder to streamline your workflow, a simple five- or six-step process can get you started.
1. Plan the Workflow
Before creating a model, you should know what you want the model to accomplish. The planning process involves listing the data input, identifying the required geoprocessing tools, and describing the desired output. For simple workflows, thinking through the process mentally may suffice. More complicated workflows may benefit from sketching everything on paper or a whiteboard. If you are unsure which tool to use or what inputs a tool requires, check the online ArcGIS Pro tool reference.
To start, click ModelBuilder on the Analysis tab in ArcGIS Pro.
Screenshot of the ArcGIS Pro toolbar, with the ModelBuilder option toward the upper left.
2. Create the Model Shell
In ArcGIS, a model must be stored inside a toolbox. When you create a project in ArcGIS Pro, a toolbox with the same name as the project is automatically created.
On the Analysis tab, clicking ModelBuilder opens an empty model window. You can also open a new model by right-clicking the toolbox folder in the Catalog pane and choosing New > Model.
After the model window opens, the next step involves setting the model properties by clicking Properties on the ModelBuilder tab.
On the General tab, select the Option To Store tool with a relative path. Using relative paths helps ensure that the model continues working properly if data is moved.
Setting these properties completes the model shell:
Click OK to open a blank canvas for building the model.
creenshot of an empty ModelBuilder interface with a prompt that reads “Add data and tools, and connect them to build a model.”
3. Add Tools and Set Parameters
With the basic setup complete, the model-building process begins. ModelBuilder provides easy drag-and-drop functionality for building and experimenting, but understanding some ModelBuilder vocabulary can help you get started.
A model consists of one or more processes. Each process has three elements: input data, a tool, and the tool’s output. Each output can become an input for the next process.
When you add a tool to a model by dragging it from the Catalog or Geoprocessing pane, its output element is also added, and both elements appear in light gray. In model terminology, gray means it’s not ready to run.
Screenshot of the ModelBuilder interface with two gray boxes reading “Buffer” and “Output Feature Class.”
When you add a tool to a model by dragging it from the Catalog or Geoprocessing pane, its output element is also added and both elements are displayed in light gray.
Double-clicking each tool allows you to set its parameters. A red asterisk next to an item in a tool dialog box indicates the parameter is required. Setting tool parameters requires paying attention to red asterisks.
If input data has selected features or records, models—such as individual ArcGIS geoprocessing tools—will process only the selection.
Once you click OK to set the tool parameters, the input element displays and the process changes color.
As processes are added, the model window may fill up. The Auto Layout and Fit to Window buttons help you see the big-picture view and zoom in and out as needed.
Click Save on the ModelBuilder tab to save your work periodically.
To visualize the model’s final output on a map, right-click its model element and choose Add To Display. Otherwise, you will need to manually add the output as a layer to the map.
Screenshot of the ModelBuilder interface with three colored boxes, a blue box reading “RockyMountainNationalPark_Trailheads,” a yellow box reading “Buffer,” and a green box reading “RockyMountainNational_Buffer.” Arrows between the boxes point from left to right.
Once created, models can be used repeatedly as a fast alternative to manually performing individual steps in a workflow.
4. Validate the Model
After adding all the tools and setting their parameters, ensure that the model will run properly by validating it. Validation is straightforward—initiate the process by clicking the Validate button with the green check mark on the ModelBuilder tab. During validation, if an error occurs, processing will stop at the process with the problem.
After determining what’s wrong and then making the fix, you should validate again. Once the model is validated, complete this step by saving it and the ArcGIS Pro project.
5. Run the Model
You have two options for running a model: inside or outside ModelBuilder. Running a model inside ModelBuilder involves clicking the Run button. As the model progresses, the tool shows a green progress bar. Once the model is run, each tool shows a green status bar and green checkmark. All successful outputs will also show a green checkmark. If a process turns gray, something needs correction and the model stops running. If you have validated your model, this should not happen.
Models can also run outside of ModelBuilder as a tool or service. Running a model as a tool or service provides advantages for collaboration and sharing.
Screenshot of the ModelBuilder interface with six colored boxes, three on the top and three on the bottom. On the top row, a blue box reads “RockyMountainNationalPark_Trailheads,” a yellow box reads “Buffer,” and a green box reads “RockyMountainNational_Buffer.” Arrows between the boxes point from left to right. On the bottom row, a blue box reads “RockyMountainNationalPark – Fire History,” a yellow box reads “Clip,” and a green box reads “RockyMountainNational_Park_Clip.”.
A green checkmark indicates a process has completed successfully.
6. Run It Again (optional)
A model’s final output may raise questions. For example, suppose a model process created a 50-meter buffer around a map feature. After examining the model output layer on the map, you might wonder what the impact would be if a 100-meter buffer was used instead. To find out, simply open the Buffer tool; enter the new distance value; and run the model again, starting at the buffer process, by right-clicking the Buffer tool and choosing Run. Because you are not altering preceding processes, you don’t need to rerun the entire model. This flexibility represents one of the key advantages of modeling.
Built for reuse, models provide an effective way to explore and test what-if scenarios. Similar to scripts, models are encapsulated workflows. Once created, they can be used repeatedly as a fast alternative to manually performing all the individual steps in a workflow. You can build a model to automate any geoprocessing workflow, whether complex or simple and straightforward.
With these essential steps for creating a simple model, you can begin building your own automated workflows.
About the author
Stephanie Oliver
Stephanie Oliver is a senior instructor with Esri Training Services who teaches ArcGIS classes on desktop and enterprise topics. Oliver has worked in the GIS industry for over 15 years, much of that in the public sector. She has extensive experience with cartography and the application of GIS to enhance transportation and emergency management workflows.
Next Article
The First Responder Who Aided Alaskan Villages She’s Never Visited
Read the next article in this issue
Get the PDF
ArcUser Spring 2026
Read this issue
View the PDF
