arcuser
Seamlessly Swap Data Sources in ArcGIS Dashboards
When working with evolving data, creating and maintaining a dashboard comes with plenty of challenges. Maybe you want to reuse your carefully crafted dashboard designs for another project, only to find it’s not as easy as it should be—and nothing is more frustrating than that yellow warning triangle signaling a data source error, knowing how tedious it is to fix.
As of the October 2025 ArcGIS Online release, the process of working with data sources within ArcGIS Dashboards has become a lot simpler and faster. Data source replacement has been one of the most requested features for ArcGIS Dashboards, and with this upgrade, authors can easily update or replace data sources, ensuring that dashboard creation, reuse, and error resolution is faster, smarter, and more intuitive.
Here are some of the things you can now do as a dashboard author:
Located under the action bar on the left, the Data sources panel gives you a bird’s-eye view of all your data sources—web maps, web scenes, stand-alone layers, and data expressions—all in one place. Using the Configure data source option, you can update or replace a data source in just a couple of steps.
Reusing a design layout and repairing a broken dashboard are two common scenarios for which this capability might come in handy. It’s worth understanding the workflow for both scenarios in detail.
Reuse Your Design Layout
Whether you’re building annual performance dashboards or creating similar dashboards for multiple clients across different regions, reusing your design and interactivity are key.
Screenshot of a dashboard displaying a network of flights by a single airline on a map of the continental US in the lower-right. The flights are indicated by lines spreading outward from Atlanta, Georgia. Colored boxes across the top display total flights, on-time flights, flights delayed, flights cancelled, and flights diverted.
This Performance Dashboard provides a monthly performance review of an airline’s operations at its Atlanta hub.
Take the Performance Dashboard above, for example. This dashboard provides a monthly performance review of an airline’s operations at its hub in Atlanta (ATL). It tracks key flight metrics such as total flights, on-time flights, delays, cancellations, and diversions. Below the indicators, two bar charts effectively display average delay times categorized by cause and flight direction. Additionally, a stacked chart shows delay patterns by day of the week.
This dashboard has been carefully built with considerable time and effort. If you want to build a dashboard with a similar layout design for a different airline hub, such as Minneapolis (MSP), you can now streamline the process using the capabilities introduced in the October 2025 ArcGIS Online update.
With the Data sources panel, you can easily swap out the existing data source for a new one in just a few clicks. This allows you to maintain the integrity of the dashboard while updating the data.
  1. In the Data sources panel, click the Configure icon next to the current data source.
Screenshot of a panel within ArcGIS Online labeled Data sources.
  1. A window opens showing side-by-side columns: the current data source on the left and the replacement on the right. Click the Change button under Replacement to browse and select a new item.
Screenshot of a panel within ArcGIS Online labeled Configure data source. A label within the graphic points to a button labeled Change, reading, “Click ‘change’ to replace item.”
  1. Layers and fields are automatically matched based on their names and types. Otherwise, manually map any unmatched layers and fields, then click Done.
Screenshot of a panel within ArcGIS Online labeled Configure data source. A label within the graphic points to the selected replacement, reading, “Selected replacement item.”
That’s it! The dashboard preview updates with the new data, and the Data sources panel reflects the changes. In the example below, the dashboard now shows the airline’s performance at the MSP hub, created by reusing the original Atlanta version of the dashboard as a template. Same layout, new insights—made possible with minimal effort.
Screenshot of a dashboard displaying a network of flights by a single airline on a map of the continental US in the lower-right. The flights are indicated by lines spreading outward from Minneapolis, Minnesota. Colored boxes across the top display total flights, on-time flights, flights delayed, flights cancelled, and flights diverted.
This iteration of the Performance Dashboard uses the Atlanta version as a template, but displays information about the MSP hub instead.
Repair a Broken Dashboard
If everything’s working fine with your dashboard, that’s great. But if something’s off, the Data sources panel will show visual cues and meaningful error messages to help you fix issues quickly and confidently.
Here’s another example—a review dashboard that displays information about New York City tree maintenance service requests, including request status, total requests over time, and request types (below). However, this dashboard is currently broken.
Screenshot of a dashboard with a map displaying green dots across a gray map of New York City. The dots indicate maintenance service requests. Four panels surrounding the map all have a label reading Data source error.
This NYC tree maintenance service requests dashboard has a broken data source.
One of the required layers is missing. As data evolves, this can happen for a variety of reasons—such as the layer being deleted, permissions being modified, or the layer being republished.
Previously, fixing this meant manually investigating and updating each element—often leading to fully rebuilding the dashboard.
Now, the Data sources panel can immediately highlight what’s wrong—whether it’s an inaccessible item, a missing layer, or a mismatched field—giving authors a clear starting point for troubleshooting.
Here are the steps to repair the dashboard:
  1. Open the Data sources panel and click the Configure icon.
  1. Replace the entire item or remap broken layers/fields to valid data sources.
Screenshot of a panel within ArcGIS Online labeled Configure data source. A label within the graphic points toa drop-down menu beside the Unknown layer label. A label within the graphic reads, “Remap to a valid data source.”
  1. Click Done.
With just a few clicks, the dashboard is restored, and there is no need to rebuild elements from scratch.
Screenshot of a dashboard with a map displaying green dots across a gray map of New York City. The dots indicate maintenance service requests. Panels surrounding the map are filled with data and labeled Requests, Request type, and Requests volume by day.
The dashboard is now populated with the formerly broken data sources.
This update is all about saving you time, reducing frustration, and making dashboards more flexible than ever. Whether you’re building dashboards for your stakeholders or adapting to a schema change, you’ll now spend less time troubleshooting and more time creating.
About the author
Shakthi Bharathi Murugesan
Shakthi Bharathi Murugesan is a product engineer on the ArcGIS Dashboards team, with a background in GIS and computer science. She’s passionate about exploring data and turning insights into compelling visualizations. When she’s not building dashboards, she’s likely reading about photons, black holes, and everything in between.
Next Article
Organize Your Data with ArcGIS Hub Catalogs
Read the next article in this issue
Get the PDF
ArcUser Winter 2026
Read this issue
View the PDF
