It’s the season of turkey trots and resolution races! A time when new and experienced runners alike sign up for 5Ks to support good causes and build community, or for marathons to challenge their endurance. For the running clubs, charities, and other organizations that plan, host, and sponsor these events, a website or application that helps attendees navigate the event grounds is essential. Developers building or maintaining these sites and apps can rely on the ArcGIS Static Maps service to improve the runner experience and keep things organized.
The ArcGIS Static Maps service is a location service that lets developers create and embed map images from ArcGIS Basemaps into any location-driven solution. It’s especially useful when a non-interactive map is all you need. The basemap determines the map style, while a geometry overlay lets you add points, polylines, polygons, and text. In a previous blog, we shared everything you need to know about the Static Maps service. Since then, the service has evolved to support even more exciting features that help developers add greater context and tell a better story
Charting the Course with Points and Polylines
Every running course has a starting point, an end point, and a line that connects the two. With the Static Maps service, users can generate a map image that displays a running path from start to finish, using markers known as points on both ends, and a polyline that outlines the specific route. For example, the image could display the path runners will take to start and complete their 5K race.
During the race planning process, race directors often make room for everything from aid stations where runners can get medical attention, to hydration stops for fueling, and checkpoints or mile makers to indicate the end and beginning of each mile. On the map image, each of these specific points can be assigned a custom symbol for easy identification. A green plus sign could represent medical aid stations, and circle markers could indicate mile checkpoints where spectators and families cheer runners on.
Defining the Grounds with Polygons and Polygon Holes
During races, designated areas on the event grounds are reserved for sponsors and event admins to set up booths for bagels and hot chocolate, or assist runners with registration. These assigned areas can be displayed on static maps with polygons representing boundaries within the grounds where all sponsor or administrative booths are located. Additionally, restricted areas such as construction zones or even VIP areas can also be represented with a polygon. Polygons representing each area could be styled differently for better differentiation.
In areas with unusual or unexpected terrain, polygon holes can be used to differentiate features within the race grounds. For example, a hole can be cut out of a larger polygon to mark a hazard inside it, such as a lake or cliff, that runners and younger attendees should avoid.
Labeling the Experience with Annotations, Text Symbols, and Styles
Users of the Static Maps service can add visually improved text annotations to maps, such as labels for key stations that help attendees find their way, race instructions, or points of interest. With the introduction of text symbol overlays, they can place custom text directly on the map wherever it’s most useful.
With the ArcGIS Static Maps service, developers can create better-branded or themed maps with an array of map styles based on any level of geographical detail needed, generating more vibrant event maps that drive audience interest.
By combining points, polylines, polygons, and custom text in a single lightweight map image, the ArcGIS Static Maps service gives developers everything they need to build clear, informative, and on-brand race maps. Runners can trace their route from start to finish, sponsors and staff know exactly where to set up, and attendees can find their way around the grounds with confidence.
To get started with the service, new users should sign up for an ArcGIS Location Platform account. Visit the Developer Documentation page to learn more.
Subscribe to the Esri Developer Newsletter and follow Esri Developers on LinkedIn to discover more developer offerings and updates.
Article Discussion:
