ArcGIS Blog
State and Provincial Government
ArcGIS Living Atlas
Map and Explore Language Data in ArcGIS Living Atlas
By Diana Lavery and Will P
Did you know that the Census Bureau has asked about language spoken at home since 1890? And did you know that there are over 1,300 languages that respondents submit every year?
Both the public and private sectors have multiple use-cases for data on languages spoken. For example,
  • to inform where different language media markets might exist for certain television, radio, newspaper, and other communications channels.
  • to inform where interest in particular products and services might exist.
  • to inform hiring decisions.
  • to respond to calls for grant applications.
The feature layer
The Dallas, TX area is visible in the map, and a PUMA in the southwest area of Dallas is selected. The pop-up reads: In the Tarrant County (Southeast)-Mansfield (North) & Arlington (Southwest) Cities PUMA 18.4% (+/- 1.5%) of the population 5 years and over speak a language other than English at home, at least some of the time. A list of the 10 most common languages here is presented at the bottom.
For all those who kept asking for more specific language data, we heard you! Thank you for bringing this up at the booth at the user conferences, in questions during webinars, and in other channels. We are proud to announce that one of the newest items available in Living Atlas is a feature layer of over 100 languages spoken across the United States.
How is this different from the ACS language layers already in Living Atlas?
The existing ACS layers in Living Atlas go down to the county and tract levels, whereas this new one does not. Also, the existing ACS layers have counts for the most common languages only, and single counts for groups of languages – French, Haitian, or Cajun, for instance. In order to gain resolution in terms of languages (three counts for those three languages), we lose geographic resolution (hence, state and PUMA level only).
What the heck is a PUMA?
A Public Use Microdata Area (PUMA) is a collection of census tracts that have a minimum of 100,000 people. Tracts are nested within PUMAs, and PUMAs are nested within states, but not necessarily within counties. Just as we do when we process our annual tract-level data, we clipped out the water for cartographic purposes here too.
A map of Fresno, CA shows PUMA boundaries in thick lines, with tract boundaries within the PUMAs in thin lines.
Pre-Configured Maps in Living Atlas
In addition to the feature layer, there are a number of pre-configured web maps available for those who want to work directly with those. Incorporate these web maps into your workflows by adding them in instant apps, dashboards, story maps, or hub sites. Additionally, you can use these web maps as a starting point, and add in your own organization’s data.
Here are some web maps available from the newly contributed feature layer, that have data at the state and PUMA levels only:
More Available Content
These web maps join others in Living Atlas that are annually updated along with our ACS layers in Living Atlas that have data at the state, county, and tract levels:
View all 16 web maps in this capstone Gallery App.
Gallery app of 16 maps about languages spoken in the U.S.
Modify These Ones, or Make Your Own
Feel free to adjust these nation-wide maps to better suit your local context. Or, create your own from a blank map. You can create dozens more web maps from the layer. We encourage you to make ones that make sense for your community.
You can also combine this layer with others for even more insights. For example, we created this map of French, Haitian, or Cajun speakers using the layers available at the tract-level (hence the grouping of these languages). The pop-up uses Arcade to call to the new PUMA-level layer to provide more information with on-the-fly calculations:
Pop-up of a census tract in Norfolk County, Massachusetts reads: In this area, approximately 9.2% of the population age 5+ speak French, Haitian, or Cajun at home, about 381 people. This is higher than the 2.5% in Norfolk County overall. Based on the ACS Public Use Microdata Sample (PUMS), speakers here are likely speaking Haitian.
Pop-up of a census tract in Lafourche Parish, Louisiana reads: In this area, approximately 17% of the population age 5+ speak French, Haitian, or Cajun at home, about 593 people. This is higher than the 5.9% in Lafourche Parish overall. Based on the ACS Public Use Microdata Sample (PUMS), speakers here are likely speaking French.
Pop-up of a census tract in East Baton Rouge Parish, Louisiana reads: In this area, approximately 1.6% of the population age 5+ speak French, Haitian, or Cajun at home, about 71 people. This is higher than the 0.6% in East Baton Rouge Parish overall. Based on the ACS Public Use Microdata Sample (PUMS), speakers here are likely speaking Cajun French.
Wrap Up / Call to Action
If you are interested in having this item updated on an annual basis when new ACS PUMS data is available, let us know in Esri Community. In general, the Census Bureau releases the five-year PUMS data file a month or two after the summary tables. For example, if the summary tables are released in early December, the PUMS file usually comes out in late January.
How do you use maps about language in your work? Which languages are most relevant to your organization? Share your projects and ask questions of other Living Atlas users in Esri Community.
Many thanks to the American Community Survey’s respondents. You are the reason we have this type of data.
Share this article
Leave a Reply
