ArcGIS Blog
Announcements
ArcGIS Online
Demographic Map Layers Retiring December 2026
By Lauri Young
Environment Layers Retiring
Esri continually reviews its online content to ensure customers have access to current and well-supported data. As data delivery methods evolve, older content may be moved through the product life cycle and eventually retired.
Esri will retire a collection of legacy demographic map layers in ArcGIS Online on December 31, 2026.
Once the supporting items are shut off, the retiring layers will no longer display or function in any maps, applications, dashboards, and other workflows that leverage these layers. Users should prepare for this retirement and consider using more up to date data. Explore current demographic data here.
Which layers are retiring?
Map layers that were previously available as premium demographic content were moved to mature support in November 2025 and will be fully retired this December.
You can view the demographic map layers here.
How to tell if an item is retiring?
Esri uses categories to communicate the life cycle status of content published through Esri organizations. Items may be categorized as Beta, General Availability, Mature Support, or Retiring. See Introducing Esri’s Content Life Cycle for more information.
How does this change affect your workflows?
After the supporting services are turned off:
  • Retired layers will no longer appear in web maps.
  • Map applications, dashboards and analyses that reference the layers may display incomplete content or errors.
  • Copies of web maps or applications may still contain a reference to the retired service. Please note copying the item does not create a copy of its underlying data.
This impact also applies to content referenced through the ArcGIS Enterprise portal. After the supporting ArcGIS Online services are turned off, the layers will no longer be accessible, even if the items appear in search results.
What should you do?
We recommend reviewing the group of retiring demographic map layers to identify items used in your maps, apps, and workflows. Check each item’s description details and consider current demographic data through ArcGIS Business Analyst Web App, the ArcGIS GeoEnrichment service, or data files available in the Esri Store. You can explore these data offerings here.
Thank you for your participation in the ArcGIS Living Atlas
Esri continues to publish hundreds of layers, maps, apps and other content in the ArcGIS Living Atlas . Thank you for your continued use of Esri content in the ArcGIS Living Atlas. We are excited to keep empowering your success with innovated and impactful content.
Related Sources
Find Information: Esri’s Retiring Items
Blog: Introducing Esri’s Content Life Cycle
View Esri’s Retirement and Deprecation Notices
Esri’s Resource Pages
Product Life Cycle Support Policy
Share this article
