ArcGIS Blog
Announcements
ArcGIS Pro
Introducing Databricks SQL Warehouse support in ArcGIS Pro 3.8
By Diana Muresan
Organizations are using Databricks SQL warehouses to query, analyze, and visualize massive geospatial datasets alongside other company data. A retailer, for example, can combine store locations (GIS data) with sales transactions (business data) to analyze geographic patterns in store performance, all within a single platform. Until now, GIS analysts often had to copy this data into a supported database before they could use it in ArcGIS Pro for spatial analysis.
Driven by user demand, ArcGIS Pro 3.8 expands its cloud data warehouse capabilities with support for Databricks SQL warehouses, extending ArcGIS workflows to spatial and nonspatial data in a Databricks lakehouse. You can connect directly to a Databricks SQL warehouse to create analytical query layers, visualize and analyze data, work with materialized views, and use feature binning to visualize large point datasets and identify spatial patterns. Databricks SQL warehouses join Amazon Redshift, Google BigQuery, and Snowflake as supported cloud data warehouses in ArcGIS Pro.
ArcGIS Pro and Databricks integration diagram
See it in action
Watch a video demonstration for an end-to-end workflow, including creating a connection, browsing Databricks content, creating a query layer, and visualizing spatial patterns in ArcGIS Pro.
Connect ArcGIS Pro to Databricks
Before you can connect, ensure the latest 64-bit Databricks ODBC driver is installed and configured on each machine running ArcGIS Pro. The driver enables ArcGIS Pro to communicate with Databricks SQL warehouses.
Tip: For optimal performance, ensure ArcGIS Pro is running on a virtual machine in the same cloud region as your data warehouse.
To connect to your Databricks SQL warehouse, select the new Databricks option, available in the Database Connection dialog box beginning with ArcGIS Pro 3.8.
ArcGIS Pro supports two authentication methods: OAuth user authentication, in which a token is generated for your Databricks user account, and OAuth machine-to-machine authentication for noninteractive connections using a service principal.
Database Connection options set to a Databricks SQL warehouse in ArcGIS Pro
Once connected, you can browse and access datasets stored in Databricks directly from ArcGIS Pro. This allows you to visualize data using familiar mapping workflows without creating copies of the data.
Note: In ArcGIS Pro, each connection targets one catalog and one schema at a time, preserving the access controls already defined in Databricks.
Explore and visualize Databricks data
There are two primary ways to interact with your Databricks data in ArcGIS Pro. The first uses SQL-based queries to shape the data you bring into ArcGIS Pro for visualization, analysis, and geoprocessing through query layers. The second uses spatial aggregation to help you visualize large point datasets and detect spatial patterns through feature binning.
Create query layers and materialized views
Query layers remain the primary workflow for working with cloud data warehouse content in ArcGIS Pro. This workflow provides a flexible approach to use native SQL capabilities in shaping the data that is brought to ArcGIS for visualization and analytics.
Create a query layer that shows only web orders based on customer location.
ArcGIS Pro 3.8 also supports creating materialized views with Databricks, improving performance for frequently accessed queries.
Once you create the query layer, you can work with it using familiar ArcGIS Pro capabilities, including visualization, charting, definition queries, and geoprocessing tools for advanced spatial analysis.
The Build Balanced Zones tool parameters with the newly created query layer as input to create balance zones for recurring customers
Creating query layers for analysis and using materialized view for complex queries are recommended when you work with data from cloud data warehouses in ArcGIS. For more best practice information, refer to the ArcGIS Blog article Best practices when integrating data from cloud data warehouses with ArcGIS Pro and ArcGIS Enterprise.
Visualize large datasets with feature binning
ArcGIS Pro 3.8 includes feature binning support for Databricks datasets to help identify data patterns while improving rendering performance and map usability.
Map and tool pane with feature binning to visualize a Databricks point dataset and summarize average brightness to identify recent wildfires epicenters globally
This capability is particularly valuable for organizations using Databricks to manage large datasets, containing hundreds of thousands and even tens of millions of records. By aggregating point data into spatial bins, feature binning summarizes the data and makes patterns clearer to identify than when viewing individual points. Whether the data represents transportation infrastructure, retail activity, government assets, or operational events, visualizing large datasets efficiently is critical.
Looking ahead
Databricks support in ArcGIS Pro 3.8 marks a significant step toward broader native integration with Databricks across the ArcGIS platform. You can connect directly to Databricks SQL warehouses, create query layers, work with materialized views, visualize and analyze data, and use feature binning, all within ArcGIS Pro.
Support for Databricks SQL warehouses in ArcGIS Enterprise is planned for 2027, enabling feature layers to directly reference data in Databricks.
As more organizations adopt Databricks as their enterprise lakehouse, these capabilities integrate GIS with your data by reducing the need to copy it and enabling geospatial workflows directly on Databricks data.
Check out the What’s New and Enhanced in ArcGIS Pro (November 2026) blog for more enhancements available in ArcGIS Pro 3.8.
Share this article
