ArcGIS Pro 3.8 is here, and we are excited to share what’s new and enhanced.
This release is all about simplifying your daily GIS workflows, so you can spend less time on repetitive tasks and more time doing the work you love. With a redesigned Arcade editor, global toolbars, dynamic spatial queries, and new plume simulation tools, this release delivers capabilities that will make your work faster, smoother, and more efficient.
Continue reading to learn more or watch the following video to catch the release highlights.
Use the links below to jump to the release highlights that matter most to you:
Keep Frequently Used Tools Within Reach
Create Arcade Expressions Faster with AI Assistance
Produce More Accessible Layouts and PDFs
Build Smarter Map Workflows with Dynamic Spatial Queries
Explore Environmental Scenarios with Plume Simulations
Preserve Memory Datasets Across Project Sessions
Additional Productivity Enhancements
What’s New
Building on the customizable view toolbars introduced in 3.7, global toolbars put your favorite commands right where you need them. Global toolbars can float and be placed anywhere on your monitor, or docked to any side of the application, keeping your workflow momentum going strong. No matter which panes or views you work with, you can quickly locate the tools you need without navigating back to the ribbon.
The redesigned Arcade editor brings schema information, profile variables, function documentation, and code completion together in one place, so you can write and debug expressions without leaving the editor. Additionally, the Arcade assistant (beta) uses AI to generate and refine expressions using natural language prompts, so you can focus on implementing your business logic rather than searching for the appropriate function.
With new enhancements to layouts and PDF exports, you can now create maps that are accessible to a broader audience. You can tag elements as decorative when they don’t convey meaningful information, which excludes them from the reading order used by assistive technologies. For map series, you can add dynamic alt text to generate page-specific descriptions for each page. Text elements can be assigned paragraph and heading tags to establish a clear document reading order. When you export your layout as an accessible PDF, that reading order is saved with the layout itself, improving the experience for people who rely on screen readers and other accessibility tools.
Create more adaptive mapping workflows with feature-linked spatial definition queries. In addition to static geometry, two new methods let you build spatial clauses from feature sets. With a fixed feature set, you choose features from a layer, and the geometry updates if you move or change the shape of those features. With a dynamic feature set, the geometry updates as you add, delete, move, or reshape features within your layer. For GIS professionals managing frequently updated operational maps, these capabilities can simplify maintenance and reduce the need for ongoing manual updates, so your maps stay current with less effort.
Explore environmental conditions with plume simulation analysis. Plume simulation models the steady-state flow of air pollutants from point, line, and polygon sources, using the United States Environmental Protection Agency’s AERMOD model within a defined area of interest. Evaluate environmental scenarios where wind speed and direction change and combine results with geographic context to better understand modeled dispersion patterns and communicate complex results more effectively.
Preserve selected memory datasets across project sessions to work more efficiently and avoid starting from scratch every time you reopen a project. Expanded saving options give you three ways to manage memory data when you save: save the project without memory data as before, remove all memory layers immediately, or save selected memory datasets inside the project file so they are available when you reopen it. Maintain connections to selected memory feature layers, standalone memory tables, and memory raster layers when projects are reopened, so your intermediate results are still there waiting for you.
ArcGIS Pro 3.8 also includes numerous productivity improvements throughout the application:
- Get real-time measurement feedback while sketching new features to help create spatial data with greater confidence.
- Geoprocessing framework changes bring general performance improvements. The greatest performance gains are seen in projects with multiple open maps, remote enterprise data sources, feature services, or network locations experiencing high latency.
- Tracing is more responsive, especially when editing large, complex networks, so you can spend less time waiting and more time editing.
- Manage coordinate systems more easily with default transformation settings, administrative controls, and usability improvements throughout the coordinate system selection experience.
- Import and merge favorites from exported favorites files, making it easier to share folder, database, and server connections across teams while automatically excluding duplicates.
- Get better visibility into deprecated or retired portal content with notifications, analyzers, and layer property indicators that help you identify issues earlier and maintain reliable maps and scenes.
- Copy symbology between supported 3D layers, minimizing repetitive configuration and helping maintain consistent visualizations.
- Load data into knowledge graphs more efficiently with a redesigned Load Data experience that supports imported load configurations, reusable load plans, data remapping, and direct link chart creation.
- Create, organize, and reuse task content across workflows with rich-text editing and text copying support in Tasks.
- Prepare and update coordinate geometry survey data more efficiently with COGO Reader enhancements, including find-and-replace capabilities and drag-and-drop support that speed up your workflow.
- Simplify Building Layer configuration by propagating layer properties and discipline-specific settings across related layers instead of configuring them individually. This reduces repetitive work and makes it faster to prepare focused 3D building content for specific workflows and sharing to the web. Read the blog
Updates to the Tools that Extend ArcGIS Pro’s Capabilities
To learn more about the enhancements made to the tools that extend ArcGIS Pro’s capabilities, check out the following resources:
- What’s New in Geospatial AI
- What’s New in ArcGIS Data
- What’s New in Imagery in ArcGIS
- What’s New in ArcGIS Data Reviewer
- What’s New in ArcGIS Business Analyst Pro
Learn More
This is just a glimpse of the enhancements improvements we have made to the tools you trust, along with many new capabilities to help you get more done in ArcGIS Pro. Visit the ArcGIS Pro help documentation to explore all the new features, and if you run into any issues with this release, don’t hesitate to reach out to the Pro team at askArcGISProPM@esri.com. Happy mapping!
Stay in Touch with ArcGIS Pro
- Subscribe to the ArcGIS Pro Newsletter to have the latest news delivered straight to your inbox.
- Engage with us on social media by following us on Facebook, or LinkedIn via our user group and showcase
- Visit the ArcGIS Pro Resources page to find a compilation of helpful resources.
- Connect with product experts, converse with fellow users, and find answers to your questions on ArcGIS Pro’s Esri Community Board.
- Beta testing for ArcGIS Pro 3.8 Assistant will begin in November. Join our Early Access Community (EAC) for the chance to test what’s new and provide feedback on features before they are released.
