ArcGIS Blog
When Should You Use the ArcGIS Pro SDK?
To extend or enhance ArcGIS Pro, you must use the ArcGIS Pro SDK for .NET. However, before you start writing code, always apply the “Configure first, customize only if you have to” principle to save time and money on development work.
If you have been using Esri software for any length of time, you may have custom code and extensions created for ArcMap that you now want to use with ArcGIS Pro. You now have a range of options to choose from that depend on whether you are dealing with simple workflows that aggregate COTS functions or more sophisticated workflows that implement custom business logic or require additional user interface.
Let’s walk through a few scenarios to help you determine the best approach for your specific needs.
A task is a set of preconfigured steps that guide you and others through a workflow or business process. A task can be used to implement a best-practice workflow, improve the efficiency of a workflow, or create a series of interactive tutorial steps.
Watch these two brief videos that demonstrate how easy it is to Use Tasks and Author Tasks. You can also review the documentation pages on Tasks.
The Python migration for ArcGIS Pro is covered in details in the documentation pages.
The good news is that the new ArcGIS Pro SDK for .NET is a modern API that leverages .NET features and patterns such as Task Asynchronous Programming (TAP). It can save you dozens of lines of code by accessing coarse grained objects and helper functions. Deployment is a simple add-in extensibility pattern, making your applications self-contained and easy to share.
Also, ArcGIS Pro is a multithreaded application, which means that it allows you to run processing tools on a different thread than the thread controlling the user interface. As such, you can build highly functional and dynamic applications that delight your customers with a superb user experience.
To help you get up to speed on the ArcGIS Pro SDK for .NET, we have posted an initial set of samples, an API Reference, and concept documentation on GitHub (as part of the ArcGIS Pro SDK beta program). Additional resources including concepts, guide, tutorials, samples, and snippets will be posted on GitHub with the release of ArcGIS Pro 1.1. You can also check out the following technical sessions from Esri DevSummit 2015:
If you are new to developing with the Microsoft .Net Framework, you can find many resources on the Microsoft website to get you started.
So, whether you are looking to build a brand new extension to ArcGIS Pro or trying to port a custom app from ArcMap to ArcGIS Pro, evaluate the new functionality and patterns that ArcGIS Pro provides as well as the capabilities of the ArcGIS Pro SDK so you can select the right tool for the job.
Subscribe
Notify of
0 Comments
Inline Feedbacks
View all comments
Next Article
ArcGIS Online FedRAMP Moderate Authorized!
Read this article
