ArcGIS Blog
Announcements
ArcGIS Business Analyst
What's New in ArcGIS Business Analyst Pro | November 2026
By Fizza Chaudhry
The latest ArcGIS Business Analyst Pro release is here, and it changes how you understand your customers, your data, and your territories. Build trade areas that reflect where your customers are coming from. Combine multiple data variables into calculated variables that anyone can understand. Style your territory maps for any audience with a click. And share maps that are more accessible to everyone. This release is all about giving you more control, more clarity, and more ways to make smarter decisions faster.
Here’s what’s new:
Map where locations have the greatest influence in the market with the new Generate Huff Equal Probability Trade Areas tool
If you have a business with multiple locations, why do some customers choose one store over another?  A simple distance map doesn’t tell the whole story. Customers may drive past one store to get to another for reasons that have nothing to do with proximity.
The new Generate Huff Equal Probability Trade Areas tool builds on the classic Huff Model by factoring in store attractiveness alongside distance. The key is that you define what makes a location attractive, whether that’s parking spaces, square footage, product variety, store age, or other factors unique to your business. You also control how much that attractiveness influences customers to travel farther. The result is a trade area that reflects each location’s true sphere of influence, and it often looks very different from a simple distance ring.
Use case: A manufacturer distributing products across several grocery chains defines attractiveness using store size and product variety. Two stores sit the same distance from a neighborhood, but one carries a wider product range. The tool shows that shoppers are willing to travel farther to reach the store with more options, giving it a larger trade area than the comparison store. With that insight, the manufacturer routes more product to the store drawing shoppers from a wider area and scales back where the reach is smaller. Smarter distribution, less waste.
Combine data, your way with new calculated variables
The insight you need isn’t always in a single variable. Sometimes it’s in the combination of multiple variables. The new Calculated Variables feature lets you combine multiple data variables from the data browser into one calculated variable using Python expressions. Sum them, average them, or add any variables to create custom scripts, such as population forecasts or age ranges. Save it, name it, and use it across your maps, analytics, and infographics.
Calculated variables can output as numbers or as text, giving you flexibility in how you present and interpret your results. This makes it easier to develop custom models tailored to your analysis. You can also share your calculated variables with other ArcGIS Business Analyst Pro users, so your team can build on each other’s work.
Use case: A commercial health organization or local state agency can combine multiple age and population variables into a single calculated variable to quickly identify neighborhoods that may need extra resources and make that map easy for anyone to understand.
Gain a clearer view of your territories with new symbology options
When you build territories from a list of locations, such as stores or customers, how those locations get grouped into territories matters. Maybe you want each location assigned to its closest territory. Maybe you want to group locations together differently based on how your business actually operates. With the options in the Boundaries Usage Method parameter, you can see more ways to shape how locations are assigned to territories from the start, so your territories reflect how you operate, not just the default.
Once your territories are built, the new territory symbology options let you switch how the map looks, so you can tailor your map to your audience and analysis without rebuilding your map every time. Choose between transparent, outlines, classic levels, or go custom based on your preference.
Use case: A sales manager has a map of regional territories. For a leadership meeting, they switch to custom symbology to show income levels within each territory, making it easy to spot which regions have the highest revenue potential. For the field team, they switch to transparent levels, so the territory colors stay visible while the streets and neighborhoods underneath remain clear. Same map, different story for different audiences.
Updated Target Market symbology built for accessibility
We’ve updated the symbology for Target Marketing output layers to make each output layer more distinct and easier to understand. The symbology was also updated to meet accessibility standards, with increased contrast and colors that are easier to distinguish for users with color vision deficiencies. When using the Target Marketing wizard or any standalone tools in the target marketing toolset in ArcGIS Pro (that produce a map output), you will see this updated symbology.
Additional resources
We’re so happy to share this latest release of ArcGIS Business Analyst Pro with you and we can’t wait to see how you use these updates and enhancements to make smarter, data-driven decisions. Below, we’ve added resources to help you with your ArcGIS Business Analyst journey:
Share this article
Leave a Reply
