ArcGIS Blog
Field Operations
ArcGIS Field Maps
Whats new in ArcGIS Field Maps (June 2026)
By Jeff Shaner
ArcGIS Field Maps is Esri’s premier all-in-one mobile app that combines map viewing, high-accuracy GPS data collection, form-driven inspections, task coordination, and location sharing into a single app that is deeply integrated with the ArcGIS system.
Building on the momentum of recent releases, the June 2026 update to ArcGIS Field Maps is here and includes many new, highly requested, features including:
  • New Multiple choice form element: field crews can now select multiple options from a predefined list within a single form field, which can in turn trigger conditional logic that reveals and/or requires additional sections of the form to be completed.
  • Attachments now part of forms: photos, videos, and documents are now part of the form and map authors can control when and how media and documents are captured using new attachment form elements.
  • Enhanced GPS metadata: additional GPS metadata fields have been added to better assess how location is captured.
  • More control over task filters: choose what fields and the default field used to sort tasks when a task filter is applied.
  • Switch branch versions:  when using branch versioned services in an online map, mobile workers can switch between named versions to visualize and edit different views of their data.
  • Improved Search capabilities: changes to how Field Maps performs queries and processes search results means no more 12 results limit per layer and the search configuration experience is now inside of Field Maps Designer.
In addition to these focused improvements, Field Maps is now powered by the 300.x version of the ArcGIS Maps SDK. Visit the What’s New topic for a complete list of changes.
Multiple choice
Multiple choice questions allow mobile workers to select more than one option from a predefined list and have their choices stored within a single form field. Multiple choice inputs can streamline the form entry process and reduce the number of fields required to capture the information needed.
Within Field Maps Designer, Multiple choice is a new choice form element type found in the Choice section of the Form builder. Grabbing the element by it’s handles, drag it onto the form canvas to set it’s properties. Multiple choice inputs are stored as comma-delimited text in a string field. The combined length of choice values and delimiters is constrained to fit within the field so choose a length that has room to support the various choices the field will support.
Choices include both a label (displayed choice) and a code (stored choice). As with other lists, it’s possible to enter each choice manually or import values from a csv file. If considering applying a Multiple choice input type to an existing string field, it is possible to generate the list of choice values from existing field values. If the string field includes a coded-value domain, the domain will need to be removed from the field first.
Optional properties include setting a minimum and maximum number of choices, a “Select all” option, and including an “Other” option. With “Other”, choose an existing field to store results or the element will create a new field.
Configure Multiple choice form elements
When capturing multiple choices, each choice appears as a check box. Visibility of Multiple choice input elements can be driven from logic and choices can drive the logic of other inputs. Tapping Select All will select all choices. Subsequently tapping Deselect All will remove the selection. If “Other” is included, selecting the Other option will display a required text box for entry.
Multiple choice form inputs support logic and include Select All and Other options for data capture.
Attachment form elements
Mobile workers can attach photos, videos, documents and audio files that provide additional information about assets, observations, or inspections. Attachments have always been associated with an individual feature or table row but not considered part of the form, until now.
Attachment elements allow authors to define how attachments are included in their Field Maps workflows. There are three input types for Attachment elements: General, Document, and Media. All input types share a common set of properties with other form elements like display name, description and support of logic.
New common properties across types:
  • Keywords – an essential part of defining an attachment’s appearance in the form and in a pop-up. Keywords indicate how and where the attachment is represented during data collection. Along with the attachment type, they also determine how attachments can be filtered in pop-ups.
  • Minimum/Maximum count – control the number of attachments captured. Setting a minimum value indicates that the mobile worker needs to upload a minimum number of attachments before they can submit changes.
  • File name – each attachment has a file name that describes it. A new Form Attachment Filename Calculation arcade profile can be used to set the file name. The profile includes a number of profile variables common to other profiles for forms like $map, $layer, $feature, $originalFeature, $featureSet, $datastore and $editcontext. Each element has a default expression that combines the attachment Keyword and time it was captured.
Unique properties by attachment input type:
  • General – allows capture of all 4 types of attachments. Choose how existing attachments, if present, are displayed in the form.
  • Document – allows file upload of documents. Specify the maximum document file size (in MB).
  • Media – allows uploading of either photos, audio, or video. Only one type of input is supported per form element. Choose photo upload size and photo source (new capture or existing or both), audio duration and audio source (new capture or existing or both), video duration and video source (new capture or existing or both).
There are 3 types of attachment form elements (General, Document, and Media).
Within the Field Maps mobile app, an inspector may be required to include a photo documenting damage or repairs, attach a captured signature. Using attachment elements, the map author can present and require the capture of attachments when and where they are needed in the form. Consider placing multiple attachment elements that target the type and categorization of media needed. Similarly, when authoring the pop-up, map authors can place multiple attachment pop-up elements and filter based on category and type.
Below are some examples of how you can present form attachment elements and pop-up attachment elements to capture and view what is needed when.
Use attachment form elements and attachment pop-up elements to capture and visualize media.
Accurate spatial data serves as the digital backbone for sound infrastructure management. Pairing high-precision GNSS receivers with ArcGIS Field Maps means that organizations can capture new data and/or update the quality of existing data directly into their GIS system.
As important as the location is, so is quantifying and understanding how locations are captured. This is where GPS metadata is important. ArcGIS Field Maps includes a pre-defined set of GPS metadata attributes that are automatically captured when using a GNSS receiver.
New GPS metadata attributes included in the June release:
  • Application settings:
    • 95% accuracy applied – when evaluating horizontal and vertical accuracy, this setting indicates if it is based on RMS or if the confidence conversion factor is applied.
    • Location profile horizontal datum transformation – name of the horizontal datum transformation if set within the location profile settings.
    • Location profile horizontal datum transformation applied – indicates if a horizontal transformation was applied by the location profile, including the following possible values: 0—No, 1—Yes.
  • Elevation attributes:
    • Antenna height (applied by various providers)- value in meters, specified when capturing accurate elevation values.
    • Orthometric height (applied by Trimble GNSS receivers only at the 26.2 release)
    • Receiver geoid model – (applied by Trimble GNSS receivers only at the 26.2 release)
  • Tilt attributes (applied by Trimble GNSS receivers only at the 26.2 release with tilt-capable receivers only):
    • Tilt compensated – was the location captured with tilt compensation
    • Tilt angle (°) – tilt angle applied
    • Tilt angle accuracy (°) – tilt angle accuracy measured
    • Tilt azimuth (°) – direction of tilt
    • Tilt azimuth accuracy (°) – measured accuracy of tilt direction
  • Correction source information (included but not yet applied by any provider):
    • Correction source type – type of correction applied (Direct IP, NTRIP, PPP. etc)
    • Correction source name – name of the correction source (example “Galileo HAS”)
    • Correction age – time delay between when a base station calculates positional corrections and when those corrections are successfully applied by your mobile receiver (in seconds)
    • NTRIP mount point – specific access gateway used when connecting via NTRIP
It’s important to Prepare your data to record GPS metadata. The Field Maps scripts repository includes several scripts for adding and updating GPS metadata to feature layers and the Add GPS Metadata Fields geoprocessing tool will update in the next release of ArcGIS Pro to support the additions.
Look for support of metadata attributes from additional receiver manufacturers coming in future releases.
Enhanced GPS metadata attributes help assess how a given position was captured
Task filters
Task filters define the dynamic to-do lists that mobile workers use to complete work every day. Task filters are powered by an expression that evaluates task attributes to determine which task features appear in the list and on the map. By default, filters are provided for tasks that are “Assigned to me”, “Unassigned”, and “Completed”. Map authors can define their own filters or add/modify the default ones. When a filter is applied, the list is sorted by one of several field values or by distance away from the mobile user.
With the June release, map authors can now modify the sort behavior using Edit sort by settings that configure how lists are sorted. For example, a water utility may want to drive their hydrant inspection list by pressure zone where each hydrant in a zone needs to be completed in a specific order. The order can be managed in a separate “Inspection order” field with values unique per pressure zone. With the pressure zone task filter applied, the mobile user will have their list sorted by values set in the Inspection order field.
Edit the sort order for task filters and help mobile workers focus on what's next.
With the ArcGIS Enterprise 11.5 release map authors can specify a named version for branch versioned services in maps they configure using Field Maps Designer. When mobile users open the online map, layers would switch to the named version specified. This provided a solution for viewing and editing against versions other than default.
New to Field Maps Designer with the ArcGIS Enterprise 12.1 release, map authors can specify a collection of named versions per branch versioned service and mobile workers can switch between each named version providing more flexibility to view and edit data when using the online map. For more information about support for branch versioning in Field Maps, read the Versioning reference topic.
Switch between named versions when working with branch versioned data sources in online maps.
Search improvements
Field Maps provides an integrated search experience that mobile users can use to find features, addresses and places, coordinates, and favorites. Search is always available and honors what is configured in the map.
With this release, Field Maps includes several improvements to the search experience for both the mobile worker and the map author.
Mobile worker improvements
Field Maps mobile app improvements center on how search performs a query and processes results so that the mobile worker can receive all results requested. The experience is further optimized by the number of data sources configured.
Searching for features By layer used to provide a maximum of 12 results. As with other data sources, they were the nearest 12 results from the center of the map. With the June update, when search is configured with multiple data sources (By layer and By address) results preview to 3 results and the data source section header includes a visual indicator of how many results were found in the layer (3 of 36 for example). Tapping the More button will expand the results list to include all results matching the defined query. If search is configured to only search using the By layer data source, Field Maps will optimize the results to instantly show all results and not limit to preview of 3.
By address search (enabled by default) is configured to query against the top-most, or first, locator set in the Geocoding section of the Utility services tab in the organization settings. With the integrated search experience, By address search results are organized into a data source category called Places. Similar to By layer search, results from By address search preview to 3 results with a maximum of 50 results. When entering the search text, Field Maps will reply with suggestions as discovered and then place results in the Places category when search is executed.
Map author improvements
The search configuration is stored in the web map and until the June 2026 release configuring the search experience for a map required exiting Field Maps Designer or opening a separate browser tab, navigating to the item details, and opening the item details > settings page and configure the experience from within the Application settings section. Designer now includes the same search configuration experience inside of the Map section of the App settings tab so its no longer required to exit Designer to make changes to the search experience.
As mentioned above, the Search tool is always available in the Field Maps mobile app and by default supports coordinate search, search of any favorites created on device, and place search (when connected). Configuring the search capability can provide a focused experience that helps mobile workers find the information they need in the map when they need it.
Search improvements include configuring the search capabilities in Designer and getting more results when querying layers and addresses.
Quality improvements
The 26.2 release includes fixes for 23 issues submitted through Esri support as well as several other quality and performance improvements.
List of public issues:
A big THANK YOU to all the beta testers of this release. We appreciate your feedback and are looking forward to meeting with some of you at the 2026 Esri Users Conference and working closely with you on our next release scheduled for early November 2026. Please stay tuned for notice of coming beta programs.
If you have questions about ArcGIS Field Maps or feel passionate about needed improvements, please reach out to us from the Esri Community page. If you would like to connect with and learn from your fellow users, please join our LinkedIn group.
Share this article
Leave a Reply
