ArcGIS Geocoding gives you the ability to transform the description of a place into a location on a map, while also allowing you to find addresses, cities, business names, and postal codes around the world. What further sets it apart is its ability to seamlessly geocode an entire file of addresses in a single operation. The Esri team continues to improve this capability and with the release of ArcGIS Pro 3.7, we are pleased to announce the following updates:
Geocoding
- Locators created in ArcGIS Pro 3.7 have the following new properties, which are supported when the locator is published to ArcGIS Enterprise 12.1:
- Exclude intersection type is a Match Options property that allows you to exclude certain intersection types from geocoded results with locators that support the StreetAddress role.
- Distance is a Reverse Options property that allows you to define a custom search distance for returning reverse geocoding results.
- The following match narrative enhancements are available:
- The MatchNarrative field was added to geocoded results.
- The Match Narrative parameter appears in the Geocode Table guided workflow.
- Access Match narrative details in the Rematch Addresses pane.
- Publishing locators
- The Batch Geocode publishing capability is available when you share locators to ArcGIS Enterprise 12.1 or later (Windows and Linux portals).
- Batch Geocode creates a GeocodeServer service and a GPServer service.
- The GPServer service is used as the Input Batch Service parameter value in the Batch Geocode geoprocessing tool and Geocode Table wizard.
- Rematch Pane
- Access the match narrative details of address candidates in the Rematch Addresses pane by clicking the Show Details button.
- The match narrative will show in a pop-up window for you to review the details.
- Locators return the MatchNarrative output field by default in output fields.
- Search results in the Locate pane can be collapsed or expanded.
Geocoding toolbox
New tools
- Split Match Narrative Into Fields
- Splits match narrative results into multiple fields and appends them to a geocoded feature class.
Enhanced tools
- Assign Streets To Points
- The Country or Region parameter now supports Argentina (ARG) and Guatemala (GTM).
- Batch Geocode:
- The new Match Narrative parameter specifies whether the match narrative is returned in the geocoded feature class.
- Uses locators published to ArcGIS Enterprise 12.1 on Windows or Linux with the Batch Geocode capability enabled.
- Create Locator:
- Use the Country or Region parameter to build locators for Argentina (ARG).
- Use the Country or Region parameter to build locators for Guatemala (GTM).
- Geocode Addresses
- Geocode Table
- The Match Narrative parameter was added to the Geocode Table operation.,
- Provides the option to add the match narrative details for matched addresses in the geocoded feature class.
Geocoding module
- The Locator class supports two new properties:
- excludeIntersectionType
- Specifies whether Virtual type intersections are excluded from geocoding results.
- Supported by the following methods of the Locator object:
- geocode
- geocodeWithSuggest
- suggest
- distance
- Defines a custom search distance for returning reverse geocoding results.
Learn More About Geocoding in ArcGIS Pro
Ready to explore the enhanced capabilities of the ArcGIS Geocoding in ArcGIS Pro? Or explore all of our ArcGIS Data products and capabilities.
Article Discussion:
