ArcGIS Blog
Announcements
ArcGIS Business Analyst
Introducing Business Analyst assistant (beta) in ArcGIS Business Analyst Enterprise | November 2026
By Sarah David
Business Analyst assistant (beta) is now available in ArcGIS Business Analyst Enterprise, once enabled by an organizational administrator.
Example of a map suggested by Business Analyst assistant (beta)
Access Business Analyst assistant (beta)
Before you can access Business Analyst assistant (beta), confirm the following requirements:
You can access the assistant on the app header.
Access Business Analyst assistant (beta) in the app header
Understand Business Analyst assistant (beta)
The assistant provides the same capabilities in Business Analyst Web App and Business Analyst Enterprise, including suggestions for creating color-coded maps, mapping points of interest, and running reports and infographics, using artificial intelligence (AI).
The primary objectives for the assistant include the following:
  • Understand your needs through natural language prompts.
  • Provide suggestions that can be run through Business Analyst workflows.
  • Allow users to refine and change suggestions to better suit their needs.
  • Teach users how to run workflows through in-app interactive guided tours.
  • Answer technical support and product documentation questions.
It was first introduced in Business Analyst Web App in beta in June 2024, then preview in June 2025, and general availability in June 2026. Now it’s making a home in Business Analyst Enterprise with its beta release in November 2026.
Sample prompt gallery in Business Analyst assistant (beta)
Understand expected differences
You may notice some minor differences. Feedback can be reported through the Early Access Community site for the enterprise assistant, instead of through an in-app survey like in the web app. The enterprise version of the assistant is in a beta stage, compared to general availability in ArcGIS Online. This means that Business Analyst assistant (beta) in Business Analyst Enterprise is not yet feature complete and users may experience unexpected behavior. Please make sure to report unexpected behavior so that fixes can be developed.
Comparing enterprise and online assistants
Some prompts and queries may return different results when comparing the Business Analyst Web App and Business Analyst Enterprise assistants. This is expected since both assistants use different AI models based on the environment. The underlying AI model in the Business Analyst assistant’s Enterprise version uses a different pattern than the web app, taking advantage of a centralized gateway that Esri maintains to the external LLMs (Large Language Models).
Learn more
For more information, consider learning about the assistant in Business Analyst Web App, including best practices for writing prompts and using tips.
Resources
Now that you’ve learned about the Business Analyst assistant (beta), we hope you’ll explore more capabilities in Business Analyst. To continue your Business Analyst journey, visit the following resources:
This article uses ArcGIS Business Analyst Enterprise 12.2 to describe the AI assistant in beta. The AI assistant is accessible in general availability using ArcGIS Business Analyst Web App.
Share this article
Leave a Reply
