ArcGIS Blog
Sharing and Collaboration
ArcGIS Business Analyst
Build accessible infographics in ArcGIS Business Analyst
By Sarah David
Infographics are presentation-ready data reports that include design elements like charts, images, tables, and maps. It is the responsibility of the infographic author to follow best practices for accessibility.
Accessible design minimizes barriers so that users relying on assistive technologies can interact with infographics. For example, accessible visual design includes high color contrast and 12-point minimum font size for readability. Accessible usability design includes formatting aria labels and grouping complex panels for screen reader compatibility support. ArcGIS Business Analyst is continually improving to be compatible with the latest assistive technologies that conform to accessibility standards and guidelines.
This article describes some of the built-in editing options that you can use in ArcGIS Business Analyst Web App to improve the accessibility of your infographic.
Aria labels
ARIA (Accessible Rich Internet Applications) labels are HTML attributes used by screen readers. For example, buttons may be labeled with user-facing text. There is underlying associated text for buttons, which is read aloud by screen readers.
For example, the Color-coded maps button in Business Analyst Web App has an accessible name that provides a hidden, concise text description for screen readers and other assistive technologies.
Color-coded maps button aria label
To see an aria label, right-click on a webpage and click Inspect. The page’s HTML coding is displayed with information like aria labels.
So what does this have to do with designing an accessible infographic? When you’re building an infographic, you can use panel options to add your own aria labels to design elements. This textual description can match information in the panel, like a chart title or variable name. By default, layer names or chart properties are used. It is recommended to review the default aria labels and edit for clarity if necessary.
To access panel options, hover over a panel and click Edit. In the Accessibility section, use the Aria label text box to add a description or edit the default description.
Aria label option
Marking a table as a “data table”
Tables contain visual information organized in columns and rows. Screen readers can contextualize this information when reading the data aloud. In order to enable this capability, it is recommended to turn the Navigate as data table option on.
Let’s look at the Retail Demand by Industry (Tabular) infographic template. This infographic template uses data tables to present information on spending by industry, containing data in rows and columns. To visualize the information that the screen reader can read from, run the infographic and right-click on the webpage and click Inspect. The page’s HTML coding is displayed.
The first data table in the template is marked as informative. The column headers are read by the screen reader with the description “column header,” whereas the content of the table is read as cells. For example, the first cell, NAICS Code, is described as a column header, whereas the spending potential index for retail trade, food services, and drinking places is read as a cell containing the value 73.
Example of HTML for an informative table in an infographic
To access the Navigate as data table option, hover over a table and click Edit.
Mark a table as informative option
Panel grouping
Screen readers read information as a hierarchy with top-level and second-level regions. Top-level navigation moves between different panels or visual elements of an infographic. Second-level navigation refers to moving within a specific panel or element.
If your infographic includes a panel with information that is thematically linked, it is recommended to group the panel elements so that the screen reader views this information together. The grouped panels, or complex panels, improve screen reading clarity.
To illustrate how regions work in infographic, open the infographic builder and click Layers to view the panels in your template. For example, the Emergency Information infographic template includes a panel that displays at-risk population information. This layer is contextualized as a region by the screen reader.
Display layers in the Emergency Information infographic
To visualize the information that the screen reader can read from, run the infographic and right-click on the webpage and click Inspect. The page’s HTML coding is displayed. To visualize the screen reading hierarchy, check the Show accessibility tree check box.
Show accessibility tree setting
The At Risk panel is a “region” in the screen reading hierarchy. This panel/region can be understood as a thematic group for related information to fall under, like the senior population variable.
Example of HTML for panel grouping
To make your own complex panel with grouped elements, click Add element, click Text, and select Panel.
Add a complex panel
To add information to the new complex panel, click + and add a title and elements like a chart or variable.
Add elements to the complex panel
Summing it all up
Accessible infographic design is two-pronged: visual and navigable. Visual accessibility includes design elements like high color contrast. Navigable accessibility includes design elements like panel grouping to improve keyboard tabbing.
This blog article describes the built-in options that you can use to improve the navigability of your infographic. For more information on accessibility in Business Analyst, see:
Resources
Now that you’ve learned about the designing accessible infographics, we hope you’ll explore more capabilities in Business Analyst. To continue your Business Analyst journey, visit the following resources:
This blog article uses ArcGIS Business Analyst Web App Advanced to create accessible custom infographics.
Share this article
Leave a Reply
