ArcGIS Blog
Announcements
ArcGIS Spatial Analyst
What's New for Spatial Analyst in ArcGIS Pro 3.8 (November 2026)
By Juan Laguna
The Spatial Analyst extension offers a significant new capabilities in ArcGIS Pro 3.8. The Suitability Modeler offers a collection of new methods to combine weighed and transformed rasters for suitability analysis. There are eight new tools that span Density, Distance, Hydrology, Local, and Surface analysis, as well as a new tool for raster conversion. Eleven tools have improvements in capabilities or performance. There is also a new way to know the size of output rasters before running a tool. Read on to learn more.
Where to get it
ArcGIS Pro 3.8 became available on November 19, 2026.
For a complete summary of all the changes that have been made for this release, have a look at the What’s New and Enhanced in ArcGIS Pro (November 2026) blog post.
What’s changed for Spatial Analyst
Listed here are the main functional areas with improvements over the last release:
  1. Suitability Modeler
  2. Conversion analysis
  3. Density analysis
  4. Distance analysis
  5. Generalization analysis
  6. Hydrology analysis
  7. Interpolation analysis
  8. Local analysis
  9. Multivariate analysis
  10. Overlay analysis
  11. Reclass analysis
  12. Solar analysis
  13. Surface analysis
  14. Zonal analysis
  15. Output raster properties
In suitability modeling, one of the steps is to combine the weighted and transformed input rasters into a single suitability map. ArcGIS Pro 3.8 introduces several overlay methods to do this.
Each method uses a different Multicriteria Decision Analysis (MCDA) approach to capture the unique interactions among model criteria. Using different overlay methods can lead to different suitability results. This gives you the capability of selecting the most appropriate method for your analysis based on factors such as the planning objective, the interactions you are trying to capture, and the types of trade-offs that are acceptable.
Lean more: Choose the right overlay method in Suitability Modeler
Raster to Cell Boundaries is a new tool in the Conversion toolbox that converts a raster dataset into a feature output that contains polygons that align exactly with the boundary of each cell in the input raster. There is an optional parameter for creating polygons for blocks of input cells. While the Raster to Polygon tool also creates polygons from an input raster, it will create a single polygonal shape that follows the perimeter of any group of connected cells that have the same value. The Raster to Cell Boundaries tool keeps all the individual cells separate.
Learn more: Introducing the Raster to Cell Boundaries tool in ArcGIS Pro
3.  Density analysis
The new Probabilistic Kernel Density tool offers a powerful way to quantify and assess confidence in a raster density surface. Traditional density analysis assumes that input locations and values are known exactly. This new tool extends this approach by incorporating uncertainty directly into the analysis, allowing density patterns and their associated confidence to be evaluated together.
The tool provides the ability to propagate three independent sources of uncertainty:
  • Sampling uncertainty—For example, variability in observations
  • Positional (location-based) uncertainty—For example, GPS error
  • Attribute uncertainty—For example, the margin of error in population values
Multiple approaches are provided for generating and summarizing density estimates while accounting for uncertainty in the input data.
Learn more: When uncertainty matters: A koala conservation workflow with Probabilistic Kernel Density
The new Calculate Euclidean Distance tool determines the straight-line distance from every location in the study area to the nearest source. Designed for straightforward distance calculations, it excludes cost distance options. It does include options to limit the maximum distance calculated, specify barriers that define obstacles, and choose between a planar (flat earth) or geodesic (ellipsoid) calculation methods.
Processing feature inputs with the Optimal Path as Line and Optimal Path as Raster tools now use less temporary disk space and consequently may return results faster.
The Region Group tool has better performance.  In testing, many operations were completed in half the time as the previous release.
This release introduces three new tools for hydrology analysis.
Drainage crossings:
There are several methods to identify the depressions that correspond to the locations of streams and rivers in an elevation surface. However, human made infrastructure such as culverts and bridges can complicate matters, particularly since LIDAR or DEM surface data do not capture those features. Identifying these locations manually can be a challenging and time-consuming process.
We developed the Detect Drainage Crossings tool to address this. This tool applies deep learning to find actual drainage structure locations using a pretrained deep learning model. As part of a larger workflow, you can also use it to create the start and end points for the associated drainage structure.
To use this tool, you must first install the deep learning framework Python API in the ArcGIS Pro Python environment. See Install deep learning frameworks for ArcGIS for more information on configuring this component. By default, the tool will use the pretrained DETReg Culvert Detection model, which requires the presence of a GPU. Ensure your system has the appropriate hardware and drivers to support GPU processing. Other pretrained models can also be specified.
Stream order:
From an input streamline feature dataset, the new Assign Stream Order tool will assign each stream segment a value that represents its stream order. Three stream ordering methods are available, Strahler, Shreve, and Hack. In contrast to the original Stream Order tool, this tool does not require an input flow direction raster.
Watersheds:
The new Watershed As Polygon tool is a companion tool to the existing Watershed tool. Instead of a raster, it creates an output polygon feature class that delineates the contributing areas for the input pour point locations. If your study area has nested watersheds, you can choose to have the watershed polygons cover the area representing the full upstream contributing area for each pour point.
The IDW and Spline With Barriers tools now use the extent of input points when calculating the default cell size. Previously, these tools used the extent of the barrier features, when specified, calculate the default cell size.
8. Local analysis
If you want to incorporate the characteristics of a raster’s cells into your analysis, the new Calculate Raster Cell Properties tool is for you. With this tool you can create a raster output that records:
  • The geodesic cell width, cell height, or cell size.
  • The geodesic area or perimeter length for each cell.
  • The X or Y coordinates for each cell center.
  • The index value for each cell row or column in the raster. The index for both rows and columns will start from 0 at the upper left corner of the raster. These index values are consistent with how the Raster Cell Iterator works.
If you select multiple properties, the tool will create a multiband output where the individual bands record the cell values for each of the properties specified.
Legacy Note:
Those of you who are long-time users of Spatial Analyst will recognize some of these as equivalents to the built-in Grid Variables that were available in ArcInfo Workstation.
The row and column index values correspond to the $$ROWMAP and  $$COLMAP variables. The X and Y coordinates for each output cell center correspond to the $$XMAP and $$YMAP variables.
The Principal Components tool now supports the Parallel Processing Factor environment for improved performance.
The Multicriteria Overlay tool has new options available:
  • When the Overlay Method parameter is set to Ordered weighted averaging, the Order Weights Method parameter has a new option Maximum entropy. Selecting it will produce a more evenly distributed pattern of rank weights across the ranked rasters.
  • When the Overlay Method parameter is set to the Ideal Point Solution (TOPSIS) option, use the new Standardize Input Rasters parameter to specify whether input rasters and ideal point values will be standardized before the calculation is performed.
The Reclassify tool now records information from the input raster in the output attribute table. When the Reclassification parameter is set to the Unique method, the new field ValueOld  preserves the original input values. For the Classify method, the ValueStart and ValueEnd fields record the value range for each class.
12. Solar analysis
The addition of several new parameters to the Feature Solar Radiation and Raster Solar Radiation tools allow for solar analysis on the planet Mars. These parameters are: Surface Albedo, Atmospheric Opacity at Start Time, Atmospheric Opacity at End Time, and Atmospheric Opacity Values.
To perform analysis for Mars, it is necessary to install some additional files into ArcGIS Pro. These files include SPICE kernels and related resources that are required to perform planetary ephemeris calculations. See the Raster Analysis Supplemental Files (RASF) topic more information on how to download and install these components.
The new Median Absolute Difference (MAD) Roughness tool calculates a short-range roughness index values for a raster surface using the median absolute difference of order 2 (MADk2) method. Applications of the output from this tool include deriving a surface friction layer for distance analysis that considers the cost of travel. The tool’s ability to derive anisotropy rasters of direction and strength can be used to examine how wind or water flows shape the features of the surface.
The new Radial Roughness tool calculates a roughness index value for a raster surface using an increment of order 2 method that computes a mean difference between each a central cell and the cells in a 5 by 5 cell neighborhood. In contrast to other roughness algorithms that consider slope, this tool only considers the local roughness when calculating the output.  It also corrects for distance along diagonal directions, in contrast to other roughness algorithms that use the eight neighboring cells.
14. Zonal analysis
As was promised in Pro 3.7, the Zonal Geometry tool now includes the same performance improvements for the Thickness option as was applied to the Area, Centroid, and Perimeter geometry types. The parallel processing factor environment is now available for the  Zonal Geometry As Table tool, so the improvements apply to this tool as well.
For Raster Analytics, a new portal tool is available to calculate Zonal Statistics.
Have you ever wanted know what the dimensions and resolution of the output raster will be without having to first run a tool? What if you want to confirm what the cell size of the output will be once you’ve set some analysis environments?
For Spatial Analyst tools, there is now a message in the geoprocessing dialog that tells you number of columns, the number of rows in the output raster as well as the cell size.
Summary
ArcGIS Pro 3.8 is another big release from the Spatial Analyst team. We hope that you will enjoy all the new capabilities and improvements that we’ve made for you.
Other blog posts are also available which provide more detail for some of the new capabilities. We here on the Spatial Analyst team encourage you to try out these changes and perhaps incorporate them into your own projects and workflows.
Connect with us
See the ArcGIS Spatial Analyst Questions page on Communities.
There is also a Spatial Analyst Resources Hub page that covers latest news and technical resources that are available.
Additional resources:
Share this article
Leave a Reply
