Airports
Weather Intelligence for Airports: Turning Data into Action and Content into Currency
When severe weather affects airports, teams responsible for aircraft movement, passenger flow, ground services, facility maintenance, safety, emergency response, and regulatory compliance have little time to respond. Lightning, heavy rain, hail, flooding, snow, ice, and rapidly changing winds are not isolated events. They are becoming more common, recurring operational risks that affect safety, staffing, maintenance, passenger experience, and on-time performance. A lightning strike near the airfield can trigger ramp closures. A fast-moving storm cell can shift gate planning and aircraft sequencing. Within minutes, a winter weather event can change runway treatment priorities.
Real-time Storm Intel Polygons indicating the imminent approach of severe hail that will likely impact Dane County Regional Airport
The question is not “if” bad weather will arrive. It is this: “Does the airport have enough location-based intelligence to act before disruption becomes operational chaos?” The impact of adverse weather can be reduced when decision-makers have timely intelligence and a shared map-based view of where conditions are changing, what is changing, and how quickly. The integration of intuitive, accurate aviation weather data with Esri’s ArcGIS platform creates real value for airport operations. By bringing precise weather intelligence into the same geographic platform where users already manage assets, facilities, vehicles, work orders, and operational dashboards, teams can better prepare, respond, and recover with a single source of truth and one shared view of risk.
From Weather Awareness to Operational Intelligence
Traditional weather information often shows what is happening in broad terms. Yet operations teams need to know where threats are, what assets are exposed, which crews may be affected, and how conditions are expected to change over time. A generic forecast may signal that storms are likely; but a real-time GIS operational view helps decision-makers understand if and when storms may affect ramps, perimeter roads, fueling operations, construction areas, passenger access routes, or critical facilities.
Esri’s ArcGIS platform provides the framework for that type of decision-making. ArcGIS enables airports to visualize live feeds, authoritative facility data, field observations, real-time vehicle locations, inspection results, and operational plans in a common operating picture. Aggregated from multiple sources into one system, weather APIs integrate directly into GIS web maps, extending that common operations picture (COP) with real-time, forecast, and historical weather layers designed for consumption in ArcGIS maps, apps, and dashboards.
The result is a shift from simple awareness to operational intelligence. Instead of toggling between separate systems, Airport Integrated Operations Centers (AIOCs) can view weather layers, impacts, airport assets, and activities in one authoritative source of truth. That helps teams make faster, more coordinated, data-driven decisions about ramp safety, aircraft movement, staffing, maintenance response, traveler communications, and recovery planning.
For airports already using Esri technology, the path to weather-enabled operations is designed to be practical. Esri maintains a close connection with a range of business partners who offer services and data that can be consumed directly in the ArcGIS suite of applications. Among them is Baron Weather, a trusted Esri partner. Baron’s ArcGIS-ready suite of weather feeds can be used in ArcGIS Online, ArcGIS Pro, ArcGIS Enterprise, Dashboards, mobile apps, and other applications. Airports can identify the weather layers most relevant to their operations, configure them in maps and apps, and use them to support operational workflows.
Precision Matters When Every Minute Counts
Weather-based operational decisions are time-critical and high-consequence. A delay in recognizing lightning risk can expose ramp personnel to danger and be in violation of FAA regulations. An unrecognized precipitation trend can quickly affect runway treatment decisions. A slow update cycle can leave teams reacting to conditions that have already changed.
Lightning is approaching 5 miles from the Fargo Hector International Airport prompting a ground stop
Drawn from meteorological expertise, aviation weather is rooted in precision and frequency. Its inclusion in GIS is non-negotiable. Graphical overlays, real-time monitoring, forecast analysis, and historical data must be available directly in every airport’s ArcGIS environment. This should include high-resolution radar, lightning detection, storm tracking, winter weather layers, rainfall intelligence, and road condition insights. That level of detail supports more confident data-driven action.
When radar updates quickly and storm information is displayed geographically, operations teams see where convective activity is developing and understand how it may move across the airfield. When lightning information is available at a granular level, airside operations managers and airlines can better determine when to pause ramp activities and when it is safe to resume while minimizing ground stops. When historical weather data is available alongside asset and incident records, planners can evaluate what happened, improve procedures, and strengthen mitigation and future response plans.
These capabilities are not just technical enhancements. They influence key performance indicators such as safety, delay duration, resource utilization, maintenance efficiency, and passenger satisfaction.
Seeing the Storm in Context
The power of GIS is being able to abstract, overlay, and see information in a geographic context. A storm polygon becomes more valuable when it is viewed against gates, taxiways, fueling areas, access roads, crew locations, drainage infrastructure, and construction zones. A winter weather forecast becomes more actionable when it is connected to plow routes, pavement priorities, deicing resources, and treatment history. A flood risk layer becomes more meaningful when it is displayed over known low-lying areas, stormwater assets, and critical infrastructure.
Baron weather’s snow accumulation layer and real-time Flight Aware feeds at DFW International Airport
A weather event can be interpreted differently by different teams, but the geographic context helps align their actions. Through ArcGIS, airports integrate weather layers into web maps, dashboards, field applications, and operational workflows. For example, a storm approaching from the west may prompt one team to stage equipment, another to adjust staffing, one to prepare passenger messaging, and another to monitor stormwater drainage assets. With ArcGIS, those decisions can be coordinated through maps and dashboards that reflect the airport’s real-time operating environment.
Improving the Passenger Experience During Disruption
Passengers experience weather disruption differently than operations teams do. They don’t see the lightning risk on the ramp, the reduced visibility on the airfield, or the crews treating pavement. What they do experience is uncertainty: delayed boarding, missed connections, long lines, and limited information. Accurate, location-based weather intelligence can help airports communicate with passengers earlier and more clearly.
Rather than waiting for disruption to appear in the terminal, staff can use operational weather forecasts to anticipate impacts and proactively coordinate messaging across customer service, airline partners, ground transportation, and digital channels. This transparency builds trust. When travelers understand that an airport is monitoring conditions, coordinating response, and communicating next steps, disruptions become more manageable. The goal is to reduce uncertainty and help passengers make informed decisions.
All-Season Readiness
Weather resilience is not limited by seasons. Summer convective activity, lightning, extreme rainfall, snow, ice, freezing conditions, flooding, and roadway impacts all create different challenges. Winter operations provide a clear example. Snow control centers monitor pavement conditions, equipment movement, material usage, runway priorities, and treatment progress as weather conditions change. Forecast information about timing, accumulation, melting, and roadway conditions support better planning and efficient use of resources. When these insights are integrated with ArcGIS Dashboards, teams see where action is needed and document response for after-action review.
A winter storm forecast showing Freezing Rain, Snow and Rain Accumulations in 1km resolution
The same principle applies to severe rain events, high winds, or rapidly developing storm cells. The more clearly an airport can see weather in relation to its people, assets, infrastructure, and operations, the better prepared it is to act with speed and confidence.
Maximum wind gusts near the Peoria International and Bloomington Regional Airports
Building Resilience with a Geographic Approach
Weather will always be part of airport operations. The challenge and opportunities are to manage weather impacts with greater precision, coordination, and foresight. By combining advanced forecasting and weather data services inside the ArcGIS platform, airports can move from reactive response to proactive resilience. That resilience starts with a map. It grows through shared awareness. And it becomes measurable when airports use this shared information to protect people, reduce disruption, allocate resources effectively, and communicate with confidence before, during, and after a weather event.
Unlock the Full Potential of Enterprise GIS
Weather data is more than a signal. It is the currency that unlocks smarter decisions, stronger coordination, and safer operations across the airport. To get the guide, please visit How to Set the Foundation of Your Intelligent Airport and discover your flight path to enterprise GIS success.
Clear skies and tail winds…
Next Article
From Similarity to Priority: Combining imagery, GIS, lidar, and geospatial AI for infrastructure
Read this article
