The ArcGIS Enterprise 12.2 release brings exciting updates to ArcGIS StoryMaps. From the ArcGIS StoryMaps assistant and new data visualization options to quizzes and expanded mapping capabilities, discover more ways to shape dynamic, interactive experiences for your audience.
Quick links
Data visualization
Frames
Interactivity
Mapping
Alternative text suggestion
In July 2025, we introduced four capabilities to the ArcGIS StoryMaps assistant to act as collaborators in your geospatial storytelling, and we’ve continued to expand the assistant over the past year.
Now, suggested alternative text extends to web maps and scenes, apps, and embeds. Instead of writing alternative text for these items entirely from scratch, you can use the assistant to generate a suggestion based on available information.
For web maps, scenes, and apps, suggestions draw from the item details and metadata, while suggestions for embeds are based on page metadata. Keeping those details complete and up to date not only helps others find, understand, and use your ArcGIS content, but can also provide the assistant with more information to work from.
To try it, click Options, then select Suggest until the alternative text meets your needs. You can also edit the generated text manually.
Learn more about the foundations of accessible storytelling with maps in our tutorial series.
Image to chart/table conversion
When intentionally integrated into a geospatial narrative, data visualization can enhance the clarity and impact of your story while creating moments of pause and reflection among longer sections of text. But recreating an existing chart or table can be time-consuming, and simply adding a screenshot can be a buzzkill. It’s neither dynamic nor accessible. Enter image-to-chart or table conversion.
After adding an Image of a chart or table to your story, select Convert image from the editing toolbar, then choose Convert to chart or Convert to table. Once the conversion is complete, select Edit and carefully review the Data and Settings to ensure everything is accurate.
Visit our Documentation page to learn more about AI in ArcGIS StoryMaps.
Data visualization
Charts
Area charts
Effective for highlighting change over time while adding depth and emphasis to your data, Area chart is now available from the Chart block. When your chart includes multiple data series, the Display multiple series option enables you to choose between Overlapping, Stacked, or 100% stacked.
Line charts
Whether it’s to better align your data visualizations with the visual identity of your story or to more naturally represent fluctuating data, you can now choose to apply Smoothed lines to your line charts.
Infographics
Word clouds
Word clouds reveal patterns in your text, enabling readers to quickly identify key topics or sentiments. Think of them as the textual equivalent of a map overview, offering a zoomed-out view of your narrative.
To add a word cloud to your ArcGIS StoryMaps content, select Infographic from the block palette and choose the Word cloud option. In Edit infographic, add your Source text in the Data tab, then move to the Settings tab to adjust text and background colors — and set the Direction of your word cloud to Horizontal, Orthogonal, or Multidirectional.
Pictographs
Effective for making data more tangible through recognizable visual symbols, Pictograph is now available from the Infographic block.
Learn how to use charts, infographics, and tables effectively in ArcGIS StoryMaps.
Frames
Swipe
Short-form storytelling with frames is an opportunity to grab your reader’s attention on the fly, but your content needs to communicate quickly. The swipe block can make that easy. Already popular in stories and briefings, swipe blocks help readers compare maps or images with a simple gesture. Choose between horizontal and vertical swipe directions, creating comparisons that feel natural for both the content and the viewing experience.
From the frame builder, select Swipe from the block palette and Add media. Select Rotate to change from vertical to horizontal swipe motion.
Flexible panel sizes
Balance text and visuals. Improve readability on mobile devices. Create more intentional layouts. Frames now feature flexible panel sizes, giving you more control over how your content is presented.
In the frame builder, Change panel size by clicking and dragging the divider between panels.
Image galleries
Image galleries are now available in frames.
Frames recently came out of beta, and we would love to hear what you think. Share your feedback at ArcGIS StoryMaps Frames Feedback.
Interactivity
Quizzes in stories and frames
It’s here, folks. Whether you’re crafting a dynamic story or classroom experience, a museum exhibit or public engagement campaign, quizzes can help transform readers from passive observers to active participants. By encouraging reflection and reinforcing key concepts, they offer a simple way to make your content more engaging and memorable.
To begin using quizzes in your stories and frames, select Quiz from the Basic block options:
- Click to type text in the Add a question and Choice spaces (you can add up to four potential answer choices for each question).
- Hover over a choice to reveal a checkmark icon; click the checkmark to Set as correct choice.
- Select Edit Quiz to find Question options, Add question, Result screen options, and Delete quiz.
- In Question options, add a Correct choice explanation and/or a Hint.
- In Result screen options, modify the default Completion message, provide Additional information, and toggle on/off the option to Allow readers to retake this quiz.
If you choose to Add question, resulting in more than one question per block, slide navigation will appear next to Edit Quiz, along with additional options to Remove this question and Reorder questions.
Currently, quiz responses aren’t collected, though we’re actively exploring capabilities like that for the future. If you have feedback about the quiz block or ideas for how it could evolve, we’d love to hear from you in Esri Community.
Learn about the efficacy of giving your readers moments of pause and reflection in our March 2026 | Finding your rhythm issue of StoryScape℠.
Mapping
Sync maps in briefings
Whether you’re comparing before-and-after conditions or examining different variables, having multiple maps on a slide stay synchronized as you pan and zoom keeps every view anchored to the same geographic context. This creates a smoother experience for presenters and readers while supporting side-by-side decision-making.
From the briefing builder, add at least two maps to a slide then click Slide actions to Enable map sync. When toggled on, all maps on that slide will sync to the last edited map; when toggled off, all maps will return to their originally specified extent.
Maps bring geospatial stories to life, so it’s essential to understand your options as an author — and how those choices affect the reader’s experience. Learn more about map extents in ArcGIS StoryMaps.
Map actions in briefings and frames
You’ve long been able to guide readers’ attention to compelling places and patterns using map actions in stories, but now it’s time to bring that same interactivity to your briefings and frames.
To get started, add a slide containing both a Map and Text. Then select the text that you want to apply Action to and Configure map action in the map editor.
Get inspired by this collection of stories that use map choreography and map actions to craft immersive geospatial narratives.
Maps in collections
Collections in ArcGIS StoryMaps provide a flexible way to organize and share groups of related content — from a series of stories or themed resources to a portfolio of your work. And as geospatial storytellers, it’s only natural that we have web maps, scenes, and express maps to share. Now, you can add these item types directly to your collections.
In the collection builder, click Add to collection, then select Map to choose items from your ArcGIS content, your organization or public content, or ArcGIS Living Atlas of the World content. You can also select Create express map to build one directly within the collection.
Start your first ArcGIS StoryMaps collection with this blog sharing best practices and inspiration for curating a navigable ecosystem of content.
For a complete list of changes and fixes in this ArcGIS StoryMaps on ArcGIS Enterprise release, view the What’s new in ArcGIS StoryMaps on ArcGIS Enterprise documentation.
Thank you to Ashley Du and Will Hackney for their contributions to this post.
All Adobe Stock images are © 2026 Adobe Stock. All rights reserved.
Article Discussion:
