ArcMap
File Geodatabase API details
(Update: You can find the most recent release of the File Gdb API right HERE)
While not exactly an early Xmas present (as a certain beaksnake may have promised), the API for the file geodatabase will be hitting the beta stage in January. Before you get your hands on it, here are some details about the File GDB API courtesy of Craig Gilgrass’ right frontal lobe:
The File Geodatabase API provides a non-ArcObjects based means by which advanced developers can work with File Geodatabases. The File Geodatabase API will be C++ based and will provide the ability to perform the following tasks:
This API is targeted for advanced developers who require access to the File Geodatabase without an ArcObjects license for purposes of interoperability. A commonly requested user scenario is to open File Geodatabase tables outside of an ArcObjects based application to view or modify data. This API does not replace ArcObjects as the recommended approach to interacting with the geodatabase.
The File Geodatabase API leverages the work done in ArcGIS 10 to simplify the Geodatabase system tables. Therefore, the File Geodatabase API only supports file geodatabases from release 10 or later. We are planning to deliver the API as a single downloadable ZIP containing:
Limitations of the File Geodatabase API
While the File Geodatabase API will support reading the schema and data of complex geodatabase types, the API will not honor geodatabase behavior on inserts, deletes or updates to the following dataset types:
The API will not prevent users from attempting to edit objects with complex behavior, the onus will be on the developer to understand what they should and should not edit through the API and avoid editing datasets that have geodatabase behavior. There will be a method called Table::IsEditable which will provide developers with the ability to determine whether a dataset can be safely edited.
Other limitations of the File Geodatabase API at its initial release:
About the author
Product Owner, UX Designer and Content Strategist on the Geodatabase team at Esri. Writer, musician, cockatiel whisperer and prolific world traveler.
Next Article
Join Enhancements in ArcGIS Pro 3.2
Read this article
